studioNest updates
New plugins, tools etc.
studioNest updates
Post by Hirazi Blue » 26 Nov 2010, 11:50
Together with the release of studioNest Gear
the following studioNest projects appear to have been updated:
Momentum, Melena and Essence
Momentum 1.3
- Passive and Active States are now properly implement
This allows animation between passive and active by setting the
mass to zero. This has been implement the same way for ICE rbds as well as
normal rbds.
Melena 1.4
- Compound to taper strandsize along strand (Set Strandsize)
- Support for using melena for normal hair (Create Melena Hair
Control) This enables you to use all of the Melena effects as well as
simulation on Strands, but then output to a normal XSI hair object, which can
be used for rendering.
irakli_san
Re: studioNest updates
Post by irakli_san » 29 Nov 2010, 08:25
Thanks for info!
jonatas
Post by jonatas » 02 Dec 2010, 11:46
I really have to take some time off work to experiment with that.
