constrain to edge or face
scrog
Post by scrog » 24 Nov 2010, 02:46
max has the option to constrain the movement of an element ( to face/edge).
how do i do this in xsi?
Re: constrain to edge or face
Post by Hirazi Blue » 24 Nov 2010, 11:37
Although I'm not entirely sure what you mean, I think what you're looking for can be found
in the two answers to the original question in this thread over @ the Area.
If this is, however, not what you mean, please elaborate... ;)
Post by rray » 24 Nov 2010, 14:34
Instead of using the ref mode like suggested in the area thread, you could use the tweak tool too which should require a few less steps:
-Activate twek tool (Make sure tweak tool transform manipulators an on (left button in viewport), and the other two buttons are set to off)
-Left click the component (point, polygon or edge) once you'd like to transform, this will show the manipulators
-Middle-click the component you'd like as the reference
For transforming along a plane you'll need to have set "Axes and Plane handles" as the manipulator style in Preferences->Tools->Transform->Translate/Scale interaction style. The others seem not to work with the tweak tool
scrog
Post by scrog » 24 Nov 2010, 18:19
rray wrote:Instead of using the ref mode like suggested in the area thread, you could use the tweak tool too which should require a few less steps:
Thank you both for your replies.
The tweak tool and mid click worked great. \:D/
Post by rray » 25 Nov 2010, 00:19
cool btw I found out during testing this that the reference that is set using the tweak tool is also being used by the normal srt transform manipulators. allows for a quick way to set this.
