PNG transparent background
agrmrs
Post by agrmrs » 18 Nov 2010, 07:47
i gave some kinda material ( red in color ) to an object ......and i needed to place a logo there ......... i saved my logo as a png ( without background ) .....but when i applied it ..... it showed the background (white color ) too .......any help would be great ......thanx a lot
Re: PNG transparent background
Post by Hirazi Blue » 18 Nov 2010, 09:07
You'll probably have to plug in the image into the transparency slot of your shader ("Phong" for instance) and activate the "use alpha" checkbox in the shader (under "transparence")(assuming you saved the png out with an alpha channel) You might also have to check the "invert" checkbox in some cases
