IOR, Glass
art
IOR, Glass
Post by art » 26 Jun 2009, 09:03
Hello, all!
Can anybody tell about IOR parameter in Mega_tk shader from puppet?
And for advanced artists, how to achieve such result:
Thanks.
Letterbox
Re: IOR, Glass
Post by Letterbox » 26 Jun 2009, 11:56
art wrote:Hello, all!
Thanks.
This look can be achieved with many shaders, from the basic lambert via incidence 2 gradient 2 reflectivity, or true glass shader, to the new arch material (google for mi's own pdf on it).
if your looking for info on ior look at http://en.wikipedia.org/wiki/Refractive_index
if you looking for a how to the arch material pdf is probably the best route.
if your looking for more detailed explanations the end links at wiki will help.
Terry
mtea
Re: IOR, Glass
Post by mtea » 27 Jun 2009, 01:38
very often it works if your objekt have a thickness...there is a plugin for xsi..another one is a plugin to extrude by normals...if you have a thickness it is easy to create shader to have such this result...i did it in my last job
julius
Re: IOR, Glass
Post by julius » 02 Jul 2009, 10:42
hi, can you tell us what's the thickness plugin you're talking about?
I tried the Kim Aldis one, but it doesn't seems to work with Softimage 7.x
danko
Re: IOR, Glass
Post by danko » 02 Jul 2009, 11:17
http://www.mindthink.de/
check this, you have to register and then can browse the projects. the one that could do the job for you is the solidify operator
julius
Re: IOR, Glass
Post by julius » 02 Jul 2009, 12:27
Thank you, but it doesn't work with 64 bits platform...wich is the one I use. :(
danko
Re: IOR, Glass
Post by danko » 02 Jul 2009, 13:40
I see, same problem as me (this is why having 2 pcs i still keep one of the two with 32bit system, lot of cool shaders/plugins don't work in 64b)...by the way, if the shape you have to give thickness isn't too complex you can even do it by hand, for things such glasses etc it's quite simple :)
Re: IOR, Glass
Post by Hirazi Blue » 02 Jul 2009, 15:00
julius wrote: I tried the Kim Aldis one, but it doesn't seems to work with Softimage 7.x
Could you be more specific? I just tried it on my 64-bits 7.01 & 7.5 and it seemed to work just fine... :-?
julius
Re: IOR, Glass
Post by julius » 02 Jul 2009, 15:54
:-\ Strange, I'll try agin... It would be a great news for me.
julius
Re: IOR, Glass
Post by julius » 03 Jul 2009, 10:05
Sorry about that, it works fine...I don't know what I've done during my first try.
