studioNest GEAR (released)
Post by Hirazi Blue » 13 Nov 2010, 19:11
Jeremie Passerin shows a preview of studioNest GEAR,
"an opensource rigging and animation toolset",
watch it on Vimeo
farhaad_yousefi
Yahoo Messenger: farhaad_yousefi@yahoo.com
Re: studioNest GEAR preview
Post by farhaad_yousefi » 15 Nov 2010, 07:26
at least if no new auto-rigger , a wounder full tool. for rigging.! 8-x
Post by Hirazi Blue » 18 Nov 2010, 08:34
Two more videos:
http://vimeo.com/16953680
http://vimeo.com/16937983
And Jeremie Passerin mentioned the following on the Mailing LIst:
Release should be next week, or at worst the week after.
Ramon
Post by Ramon » 18 Nov 2010, 20:59
people waiting!
Studionest kratos and momentum was beautiful in preview videos, and its have a lot of bugs and i think its still not finished, interesting what will happen with this tools.
studioNest Gear released
Post by Hirazi Blue » 26 Nov 2010, 11:41
studioNest Gear has been released.
Get it here
craft
Re: studioNest GEAR (released)
Post by craft » 27 Nov 2010, 12:07
thx for the info, HB ;)
irakli_san
Post by irakli_san » 27 Nov 2010, 16:21
WAAAAA! Thanks!!!
Post by Hirazi Blue » 30 Nov 2010, 14:56
A new "minor" version has already been released.
v 1.0.1
- Rig fix : Twist wasn’t properly working.
Affected components : arm_2jnt_01, leg_2jnt_01, leg_3jnt_01, wing_2jnt_01
Require guide update : No
Require rig rebuild : Yes
Animation compatible : Yes
- Bug fix : Create Kine Spline and Create Kine Spline Roll command weren’t working.
Get it from here
Post by Hirazi Blue » 01 Dec 2010, 16:30
v 1.0.2 released
- Rig fix : Twist was still not properly working in extreme position. Thanks Galvin for testing.
- Feature : Added information about used components and gear version inside generated rig
irakli_san
Post by irakli_san » 10 Dec 2010, 15:09
just a simple code to register Python in windows environment variables. maybe someone will find it useful.
change C:\modules\ with your path to modules folder. save as bat file and run as administrator
@echo off
C:\Windows\System32\reg.exe ADD "HKCU\Environment" /v PYTHONPATH /t REG_EXPAND_SZ /d "C:\modules\\"
Post by Rork » 13 Feb 2011, 15:12
I'm not really the Python head, but can one run the Gear tools with the python version that comes with Softimage?
If so, can somebody explain how to get things installed on the modules part.
cheers,
Post by Hirazi Blue » 13 Feb 2011, 15:22
It should be possible.
Quit Softimage
The easiest way (to explain?) is probably to add the following to your setenv.bat
set PYTHONPATH=[your very own path to the modules folder here]
Restart Softimage
Haven't tried this myself, as I used the PYTHONPATH on the level of the Windows environment variables, but this should work. If not: let me know...
Post by Rork » 13 Feb 2011, 16:01
Nope, not working.
I have set the path in the setenv.bat to the modules folder:
rem StudioNest GEAR Python Modules
set PYTHONPATH=\\SERVER\xsiwg\StudioNest_2011\modules
but the test command gives me a error about the module not found.
Do you have Python installed outside SI? I'm trying to get it working for SI SAP. All other stuff is working for the StudioNest tools.
All other Python bases tools do work in SI, so installing Python separate from Si isn't neccessary for these tools.
Will try again tomorrow, any more tips are welcome.
Post by Hirazi Blue » 13 Feb 2011, 16:06
Just as a test: what happens if you temporarily locate the modules folder locally and not define it by an UNC address (but by a garden variety "C:\LookHere\modules")?
Or maybe place the workgroup address between quotation marks...
(belated edit: and double all the backslashes)
Post by Rork » 14 Feb 2011, 09:27
Got it working with the lines mentioned in my previous post:
I probably was a bit too impatient yesterday ;)
So it's working with the internal SI install of Python, and in a workgroup without much hassle.
Repo steps:
1. Create workgroup folder, e.g. 'StudioNest'
2. In the plugin manager, connect to this workgroup folder, and be sure to move it up so it's the first workgroup in the list
3. Copy the 'modules' folder from the downloaded gear zipfile into the workgroup folder, so you get 'StudioNest\modules'
4. Edit setenv.bat with the PYTHONPATH line, linking the python scripts. Edit this file with a text editor on admin rights, or change the properties of the SI 'UserTools' link/app to 'run as administrator'! If not, you cannot save the file...
5. After restarting SI, go to the plugin manager, and install the gear addon into the StudioNest workgroup
6. Restart SI again, and see the GEAR menu appear. Open up the demo scenes to see if all works, if so.... :ymparty:
farhaad_yousefi
Post by farhaad_yousefi » 07 Aug 2011, 08:40
Rork wrote:Hi,
Repo steps:
hi .
could you explain it for a newbie like me.?! :d
i can't find PYTHONPATH line inside setenv.bat..!!! :-??
