I'm stuck with 768 x 1024, and the SceneSearch bar "wraps" at this res. It ends up under the menu row, doubling it and using up precious space.
I don't use it. Is there a way to hack it out of the layout?
Remove SceneSearch from top right of layout?
Re: Remove SceneSearch from top right of layout?
If by SceneSearch you mean the so-called "Quick Filter box", then yes you should be able to hide it:
right-click the toolbar and deselect (from the "pop-up" mini-menu) the item you want to hide (in this case: the "Quick Filter box")
Sarge
Stupendous! I was ready for a late night of hackery but I should have known XSI already thought of it.
Is there anything that doesn't totally rock about this software???
Thanks very much, Hirazi Blue!
