Softimage trial issue
Nizar
Post by Nizar » 21 Oct 2010, 18:55
I would like install softimage 2011 trial on my friend PC, but I have many trouble about.
Softimage install start smooth, but when try install .net framework 3.5 sp1 appear a red X, go away and install correctly softimage. When restart, after installation, softimage receive this message:
Error: there is no interactive license available softimage
it is installed .net framework 4, so I think softimage don't install 3.5 because is older release.
I tried unistal and install three time, but nothing to do, I receive the some error message.
Any idea about?
Re: Softimage trial issue
Post by xsisupport » 21 Oct 2010, 19:18
Is this Windows XP?
What does it say in %TEMP%\Autodesk_Softimage_IF.log ?
// Steve Blair
Nizar
Post by Nizar » 21 Oct 2010, 19:21
It is windows 7 64bit
what is? :ymblushing:
Nizar
Post by Nizar » 21 Oct 2010, 19:51
Ok, I find the file in temp fold.
I find the file, and open it. Don't nothing so important (all done, apart installation Framework 3.5 sp1, Failed Failure is ignored, result=1603
Post by xsisupport » 21 Oct 2010, 20:07
Here's a short video (no audio)
// Steve Blair
Nizar
Post by Nizar » 21 Oct 2010, 20:20
thanks very much
Only framework signal a failure message (as below report), the other ones are all positive message , like this one:
install autodesk softimage 2011 64 bit succeeded
But XSI don't start, and give us the error message...
Post by xsisupport » 21 Oct 2010, 20:29
Do you get this error:
or this:
Error: there is no interactive network license available
It makes a difference for the troubleshooting.
// Steve Blair
Nizar
Post by Nizar » 21 Oct 2010, 20:32
Thanks for your support.
Exactly is:
error there is no interactive license available to run autodesk softimage 2011
Post by xsisupport » 21 Oct 2010, 22:30
I haven't seen this problem in awhile. Try this:
http://usa.autodesk.com/getdoc/id=TS13901061
// Steve Blair
Nizar
Post by Nizar » 21 Oct 2010, 22:34
Thanks again. I just find the page you suggest, and this other http://www.xsibase.com/forum/index.php?board=9;action=display;threadid=40750
in any case don't work... now I try download Maya (as suggest in XSI base), install this trial and try again
and another similar on Area but it was a 3dsmax issue.
It is really strange, because I have the some machine, but with a different VGA. My friend pc is new and he install windows 7 64 only yestarday
Nizar
Post by Nizar » 21 Oct 2010, 23:15
Ok, after installed Maya 2011 (indeed nice interface) install again XSI and now it work correctly... :-?
