quickinset
QuickInsetAuthor: Piotrek Marczak
Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like interactive extrude, bevel and inset operations without showing a property page. Piotrek's notes from the si-community thread: Extruding along normal is available only in 2012 SAP for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen subdivision highlighting is supported only for level 1 and only catmull-clark J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool I've used it to model few production objects and it's pretty useful.
vit
Re: quickinset
Post by vit » 27 Mar 2019, 09:48
Hello. Who knows how to build this plugin from source. I wanted to compile the plugin with my custom hotkeys. I tried to compile, but I get errors. Thanks in advance.
Re: quickinset
Post by rray » 27 Mar 2019, 10:55
What kind of error?
vit
Re: quickinset
Post by vit » 27 Mar 2019, 12:27
When I try to compile the solution, I get this error:
1>------ Build started: Project: pmQuickExtrude, Configuration: Release x64 ------
1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\x64\Microsoft.Cpp.x64.targets(152,5): error MSB6006: "CL.exe" exited with code -1073741515.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I tried to compile in visual studio 2010 express and in vs 2012, but I get the same error.
vit
Re: quickinset
Post by vit » 27 Mar 2019, 12:39
I started getting this error when I added the path C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\bin\ to the environment variable.
Without this path I received an error
1>------ Build started: Project: cable, Configuration: Release x64 ------
1>TRACKER : error TRK0005: Failed to locate: "CL.exe". The system cannot find the file specified.
1>
1>
vit
Re: quickinset
Post by vit » 27 Mar 2019, 12:43
Sorry for the name of the cable in the message. I tried to compile an empty project. Same error with quickExtrude
Re: quickinset
Post by rray » 27 Mar 2019, 12:48
If this happens for simple Hello world project too, it's an issue with the Visual Studio installation. In that case I would try reinstalling VS (maybe upgrade to community version 2017)
vit
Re: quickinset
Post by vit » 27 Mar 2019, 13:01
Thanks for the advice.
vit
Re: quickinset
Post by vit » 27 Mar 2019, 17:44
I only get this message when I run visual studio using the bat file.
Maybe someone knows how to overcome this error? I am using Visual studio 2012.
vit
Re: quickinset
Post by vit » 27 Mar 2019, 17:46
This is an error when compiling a project.
Re: quickinset
Post by rray » 27 Mar 2019, 18:45
Which bat file do you mean? Can you post it? It might change some path to point VS to the wrong CL.exe
vit
Re: quickinset
Post by vit » 27 Mar 2019, 19:18
I created a bat file to run as described on the site. http://docs.autodesk.com/SI/2015/ENU/So ... lugins.htm
@echo off
call "C:\Program Files\Autodesk\Softimage 2015\Application\bin\Setenv.bat"
call "C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\vcvarsall.bat" amd64
set PATH
set "XSISDK_ROOT=C:\Program Files\Autodesk\Softimage 2015\XSISDK"
"C:\Program Files (x86)\Microsoft Visual Studio 11.0\Common7\IDE\WDExpress.exe" /useenv
echo on
I apologize in advance, I guess I'm doing everything wrong. Is it possible for someone to compile this plugin with my custom hotkeys? Or tell how to do it correctly.
vit
Re: quickinset
Post by vit » 27 Mar 2019, 19:28
I found a mistake. And everything started to compile. Sorry for the trouble.
Re: quickinset
Post by rray » 27 Mar 2019, 20:30
no worries! what had been the issue?
vit
Re: quickinset
Post by vit » 27 Mar 2019, 23:03
In the bat file you need to delete / useenv. This solved the problem and the program was compiled.
Like this
