quickinset
QuickInset Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like
interactive extrude, bevel and inset operations without showing a property page. Piotrek's
notes from the si-community thread: Extruding along normal is available only in 2012 SAP
for operations that relies on SI units you drag in component's normal direction,
for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
subdivision highlighting is supported only for level 1 and only catmull-clark
J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower
LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool
I've used it to model few production objects and it's pretty useful.
geoath
Re: quickinset
for a reason i can't find i can't make it work..
after installation:
-i go to the plugin manager>pmQuickExtrude(addon)>Plugins and the icon before the name of the tool has a red triangle.
-also i noticed after the icon, it writes pmQuickExtrude.dll shouldn't it write the name of the plugin?.
when i right click on the pmQuickExtrude.dll and choose properties i get a message : library not found" with the instalation path..
any idea what might be wrong?
si2012, win7/64bit
ps: the previous edition of the tool (the quick inset one) worked fine..
after installation:
si2012, win7/64bit
Re: quickinset
Hi, red triangle means for some reason dll was not loaded.
I compiled the x64 bin against 2012 SAP libraries.
Probably I should link with 2012 libs...anyone with 2012 non-SAP x64 can confirm it's not working?
Memag
Re: quickinset
Working fine here. SI SP1 64bit, win 7.
Testing ground. What a nice, powerful tool.
Re: quickinset
Thanks memag
well due to my limited knowledge of c++ voodoo I can recommend only installing vs2010 redist. http://www.microsoft.com/download/en/de ... x?id=14632
geoath
Re: quickinset
thanks, I'll try it!
YES, PROBLEM SOLVED
Thanks a lot origin, both for the solution and the great tool!
YES, PROBLEM SOLVED
Re: quickinset
This tool ROCKS!!! Great work!!!
Is there some trick to getting this to work with keyboard mapping? I mapped it and it does nothing...
jamnique
- Skype: darthjamnique
Re: quickinset
Just WOW! This is one amazing tool. Feels so organic and intuitive. Hats off and thank you for sharing it.
bottleofram
Re: quickinset
When the left icon is clicked and it says "extrude along axes", it should extrude along XYZ, right? Doesn't really work for me. It always extrudes along normal.
Can anyone confirm this?
Memag
Re: quickinset
I think it doesn't work here either.
Is it possible to "remember" the button state, like tweak tool does?
Re: quickinset
memag: yes it's possible. I had to disable this feature until I rewrite some parts of code.
Axis in 'E.A.A' means local component's axis (by default set to Y axis)
extruding along other axes is practically useless (you can hit enter after extrusion, or inspect OP and play with options to see difference)
I think the only difference you will see between these 2 modes is when you extrude group of polygons. extrusion along normal extrudes each component along it's own normal, while e.a.a. will 'averange' normals of selected polygons so extrusion will go in only one direction.
Memag
Re: quickinset
Okay, thanks Piotrek.
Do you think you can pull out "orient" polygon option (LMB+MMB?), like in this video?
I will totally understand if you choose to ignore me.
Re: quickinset
Interesting...will see ;)
meanwhile you can use sticky keys (transform tool in this example) to move polys around while quickextruding
bottleofram
Re: quickinset
Ok, I assumed it somehow recognizes the direction im dragging and selects the right axes. Heres what i thought to achieve:origin wrote:Axis in 'E.A.A' means local component's axis (by default set to Y axis)
http://www.zshare.net/video/989995312b1e6630/
Note: the first is tweak tool. It kinda works but its very unpredictable and unpractical...
scumworks
Re: quickinset
Man, awesome plugin. I got one question tho.
Would it be possible to have the tool work w/o having to click on your selection? So just by holding the ex. supra key, you could extrude/bevel the current selection. Sometimes very easy to missclick an edge instead of poly (ex. with small selections).
Once again, killer work.
Memag
Re: quickinset
The tools in the video, I posted above, do just that.
Clicking and dragging outside of selection performs the operation ,if you hold the key that is.
Would be cool to see it in quickExtrude.
Re: quickinset
no problem
memag, what's the software you used in this video?
