quickinset
QuickInset Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like
interactive extrude, bevel and inset operations without showing a property page. Piotrek's
notes from the si-community thread: Extruding along normal is available only in 2012 SAP
for operations that relies on SI units you drag in component's normal direction,
for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
subdivision highlighting is supported only for level 1 and only catmull-clark
J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower
LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool
I've used it to model few production objects and it's pretty useful.
Chris_TC
Re: quickinset
I wasn't knocking your tool by the way, I think it looks great. And having additional tools available to choose from is a great thing.
Ahmidou
Re: quickinset
it will! ;)
origin wrote:to be honest
having bevel, extrude and inset in single tool is quite logical.
but adding some more feature, more key combinations will also make tool more confusing.
Now I'm Max user for 10 years now but I prefer modeling in XSI ALOT.
The only thing xsi lacks of is more tools that fit xsis genius workflow
I will wait with releasing final version of my tool, hoping SAP will include source code for new split edge tool.
Re: quickinset
2008. Few months ago I tried 2010 but had alot of errors so I gave up.
Re: quickinset
You need to add text opengl32.lib in project->(projectname) properities->configuration properties->linker->additional dependencies
calmasacow
Re: quickinset
How does the bevel work. I'm using it with the 2012 SP1 on x64 and I cannot get the Bevel to work what are the keys?
Memag
Re: quickinset
There is no "bevel" in current build.calmasacow wrote:How does the bevel work. I'm using it with the 2012 SP1 on x64 and I cannot get the Bevel to work what are the keys?
Only Origin can use it, for now.
calmasacow
Re: quickinset
Boo this man!
Just kidding. I can't wait to see this. I hope it gets released quick after SAP comes out.
scaron
Re: quickinset
this is not true, i believe its half and half. thickness and cap hole are ICE modeling. smooth edge loop and extrude along normal are traditional operators.Throneinc wrote:i just confirmed that all the new 2012.5 modeling tools are in ICE format, just a headsup.
s
scaron
Re: quickinset
@~13:00Throneinc wrote:http://www.youtube.com/watch?v=aPv3ysEf ... embedded#!
scrap through, he did mention that all the new modeling tools are in ICE, he opened a few operator aswell.
notice it didn't change when he selected the extrude along normal op and refreshed the tree? cause its a traditional operator, same goes for the add smooth edge loop.
regardless these operators can still be driven from a custom tool sdk, parameters are still parameters regardless if they are in ICE or C++ property pages.
s
Re: quickinset
Sorry guys It will take some more time for update. I don't have time now due to a lot of work
meanwhile I was working in my spare time (which I don't have) on this http://vimeo.com/30157356
Re: quickinset
Hi guys, I've updated first post with new version. (32bit version was not tested but should work...)
bottleofram
Re: quickinset
Great stuff as always, piotrek.
Don't know if this has been discussed already, but would it be possible to implement some of the advanced selection characteristics into the tool? For example, edge loop selection on double click and shortest path selection. That would useful when beveling the edges interactively. Right now it seems you can only select the edge one by one...
gfxman
Re: quickinset
uao! That's amazing! Great Work and thx for release it has a free plugin!
Memag
Re: quickinset
Great to see it finished!
Congratulations on a brilliant tool and thank you very much for releasing it Piotrek.
Re: quickinset
yep you can only select subcomponents one by one.bottleofram wrote:Great stuff as always, piotrek.![]()
I was thinking about adding those,
but then again if you work with tool in sticky mode, you can always turn on selection tools in supra mode to select some stuff.
bottleofram
Re: quickinset
Oh, I see. That'll work!origin wrote:yep you can only select subcomponents one by one.bottleofram wrote:Great stuff as always, piotrek.![]()
Hopefully you receive enough requests to eventually implement it (for the sake of convenience), but the tool is an immense improvement for the workflow as it is, nonetheless. Thanks
