Indeed! I'm sure it's just not too tricky, but if you'd like to wait a bit, I'm going to prepare a simple EMFluid to RS sceneowei wrote: 03 Jan 2018, 19:27Yes, just cache the volumes as vdbs and use the volume object in redshift to render themjamination wrote: 02 Jan 2018, 18:50 Is anyone using the fluids with Redshift, if so what is the procedure to do so.
thanks
Cheers,
Oli
I've already prepared an Explosia -> RS one, using one of the factory samples which I'll post in a bit.
It's very "live" (and VERY FAST), VDBs are written on the fly on change, and the RS Volume grid (in the same scene reffering to the current project path) picks it up on region update,
so it's pretty seemless and direct, and I don't see why the same wouln't work with EMFluid.
Stay Tuned!
