Emit Strands though Object and Collide ?
Falam
Re: Emit Strands though Object and Collide ?
Post by Falam » 19 Dec 2013, 03:58
Get Data at Previous Frame ? If this is correct ? I don't always understand the replies.
ChrB
Post by ChrB » 19 Dec 2013, 09:30
Falam,
I suggest you pick up some more basic level ICE knowledge. You seem to be lost a bit in a deep fog. I recommend Thiago Costas ICE tutorials which are available to buy at cmivfx.com. They will give you a good understanding of what ICE is and the logic of it.
Arnold for the masses!
Falam
Post by Falam » 19 Dec 2013, 12:11
ChrB wrote:Falam,
I already watched that tutorial, I didn't understand his sense of teaching although, he is knowledgeable, but not all teachers can captivate all it's students.
Post by Hirazi Blue » 19 Dec 2013, 12:41
Personally I wasn't all that impressed by Thiago's training set either. From a practical standpoint your best bet at "project based" training probably would be to watch the ICE part of the "Softimage 7.x Certified Training", as it was uploaded by AceMastermind on YouTube. The links can be found here.
Falam
Post by Falam » 19 Dec 2013, 13:18
After watching most of the commercial ICE tutorials, many were sub-par, IMO.
I don't see anything in AceMasterMind ICE tutorials that would benefit me from understanding the hiccups I experience using ICE. I've watched commercial tutorials and the teacher was excellent, while others the instructor, I suppose assume we all have his brains.
Some tutorials will repeat the info I know and ignore the info I want to know. ~x(
It's understandable (sarcasm) because many in the Softimage community understand the framework of ICE, we all share their brains, we each can't be unique, it is just a black and white world, sure, whatever.
Post by NNois » 19 Dec 2013, 14:14
maybe you need to rewatch them again and again because, here, it's embarrassing you haven't put your icetree in a simulated region for simulated particles
Falam
Post by Falam » 20 Dec 2013, 01:57
NNois wrote:maybe you need to rewatch them again and again because, here, it's embarrassing you haven't put your icetree in a simulated region for simulated particles
Who is it embarrassing, I'd like if they stood up !
The ICETree is in a simulated stack, you like to harass but not help. It would be best if you stuck your nose out of the thread if these are the kind of replies you can only write.
Falam
Post by Falam » 20 Dec 2013, 03:10
When you watch a tutorial and all they are doing is saying..do this then this, then do this, and this will cause this. And you paid for it and you can't reach the author and ask questions, then don't make the tutorial if questions from users are bothersome.
ICE should be mastered not tinkered with, it's a remarkable tool, tinkering is a waste of time I might as well play the board game connect four if I'm going to tinker and hope I come up with something workable.
Post by NNois » 20 Dec 2013, 08:52
well,
in fact you can just try to start with the Softimage documentation ...
in regard to your drawing you can do this http://download.autodesk.com/global/doc ... d30e286173
note that it miss the gravity force, just follow the manual and plug the add force node the the force input of the simulation root, http://download.autodesk.com/global/doc ... d30e286173
now about your blue lines, this is "spawning" so you follow the manual with http://download.autodesk.com/global/doc ... 70926-008D
and so on...
now add the strand trail and you're good.
here a rapid screenshot of it without the forces and spawn part.
nono
Falam
Post by Falam » 20 Dec 2013, 12:02
I have to use a simulation root ?
Oh that is what you meant by a simulation root, your vocabulary threw me way off.
How do I join my collide branch with my existing tree ? I'll have to post screen shot later !
Post by NNois » 20 Dec 2013, 12:50
a simulation root is for people who don't know the right order of things...
but if you do, the right order is:
Emit particle ->port1
Add Forces ->port2
Spawn/Bounce/Flow ->ports 3 to X
Simulate node -> port X+1
strands trail -> port X+2
Falam
Post by Falam » 20 Dec 2013, 13:02
My concern is the collide node !
Post by NNois » 20 Dec 2013, 14:24
well, what did you try ?
because in fact you collide branch was not working if i understand right so why insisting using it can you just try what i and the softimage docs recommend you?
Falam
Post by Falam » 20 Dec 2013, 19:57
Take a look.
Post by NNois » 20 Dec 2013, 22:06
Your red nodes have been discussed by stephen and he is just right
But, you are using the "basic collide" node it's a deep ICE node for collisions ! This is clear, right from the first words on the docs http://download.autodesk.com/global/doc ... d28e548269
This node output a location, time etc and need even more complex inputs, do you know how to deal with that ?
Just "Open" the "bounce of surface node i recommend you or even "test collision with surface" you'll see why, in you case, you can't use it. Until you want to recreate for fun the softimage ice nodes.
Plus I would like to add in response to your precedent comment why don't using the Simulate root node if it would be more simple for you ???
If you want to go deep in ICE you should start with the basics nodes then go deeper to understand or customize, but not starting like you not knowing even where to start.
Falam
Post by Falam » 21 Dec 2013, 00:19
I don't understand what you are saying !
I do, yet some parts I don't. I want to know why the geometry node is red, not how I should learn, or what I should do. Why is it red, what is the reason ?
Since you are the only one who is going to reply, I doubt I"ll make any progress.
Moderator edit: As per Falam's own request I have deleted his account & closed this thread - HB
