Matcap shader for Softimage
Matcap shader for SoftimageAuthor: Andy Moorer
[..] I've banged together a Matcap (archive) shader (aka litsphere) in metaSL which works in the Softimage High Quality viewport. You know how in Zbrush models look kind of like clay or other materials as you work on them? That's Matcap shading.
It's provided "as-is" but since its metaSL it should work for everyone regardless of graphics card as well as look the same in HQ/real time, and mental ray. That's the theory, anyway.
local backup: litsphere_packaged.xsiaddon"
Falam
Re: Matcap shader for Softimage
Post by Falam » 23 Feb 2013, 02:40
Daniel Brassard wrote:
If only it didn't crash Softimage with HQV it would be nice to model with it.
So version 1.1 crash Softimage?
It still crashes Softimage, even version 1.1, argghhh X( HQV is a pain, when only a sphere will work. X( :-\
Post by Daniel Brassard » 23 Feb 2013, 02:50
Work for me, MR render, HQV on and models other that a sphere.
I am using my old computer AMD Athlon x2-4400, window XPsp3 32bits, NVidia 256 GTX videocard and Softimage 2013.
I don't know why it crash for you. Can you capture the error message?
Dan
Falam
Post by Falam » 23 Feb 2013, 03:10
Dan
Softimage closes so fast, I can't capture anything :(
Matic
Post by Matic » 25 Feb 2013, 21:13
That's awesome, thanks for following up on this Daniel... Was distracted on a gig and testing another product and was thrilled to come back and see this.
Daniel Brassard wrote:@ ActionArt and Matic,
I modified the program a bit, try this one and let me know how it work. Modification made:
  • Removed the hardcoded texture "relief_map_1_height.dds".
    Modify the soft_range parameter by removing the float type inside the parenthesis
    some cleanup of the code.
Matic, hope you didn't mind me muddling with your code.
@ Falam
Correct, the light interaction will have little influence on the Matcap, this is intended and the correct behaviour. See it as a baked light texture.
The shader is intended for use in modeling/sculpting ala Mudbox/ZBrush.
Post by ActionArt » 25 Feb 2013, 21:32
Yes indeed, I've used it a fair bit now and so far, so good! :D
Falam
Post by Falam » 25 Feb 2013, 22:28
Glad it's working for some :)
kilik
Post by kilik » 31 Mar 2013, 15:04
hi ! it's shader is so fun i try bake him ! and i have strange result someone can say me more ? about baking
sirdavid32
Post by sirdavid32 » 24 Apr 2013, 19:30
I just HAD TO LOG ON to say: THANK YOU SO MUCH!
Other than that, is there a way to make this work in softimage 2012?
I saw the post about Helge M. and the matcap shaders. I´ll go check them out as well.
This material only works for Softimage 2013?
