LivePaint plugin
LivePaint
Here is an alpha version of a paint tool that doesn't need weight maps to deform a
mesh. It's far from finished but is usable for painting push and smoothing. To install,
copy the dll in your plugin directory then run this jscript command in the script
editor: LivePaint()
Some things you need to know: only 32bit for now RMB to choose between push and smooth shift drag to change the brushopacity control drag to change the brush radius it only work on freezed objects undo will revert the object to its state before freeze there are many bugs, use it at your own risk — Have fun.
local backup: LivePaint.32.dll LivePaint.64.dll (copy to a Plugins directory)
Re: LivePaint plugin
Bugs so far
- changing brush size is bugged (diameter is not clipped to viewport, can be < 0 size )
- brush position and point selection is not multipled by source object srt matrix
- it was compiled with debug?
Bugs so far
Ahmidou
Yes I know about them, I focus on the Undo. As winter is coming here, I should have more time in the nextorigin wrote:Thanks!
Bugs so far
few week to consolidate it.
It was compiled in release but it is still very wip, that's there are logged messagesorigin wrote: - it was compiled with debug?
Thanks for the feedback!
A.
Clappy
Arrgghh...getting the same error as other posted earlier ("// ERROR : Object expected - [line 1]"). I am on Windows 8.
The previous version worked for me on Windows 7, so I must be missing something, or it is not compatible with W8.
Frustrating as I would definitely use this in my daily workflow....
Any ideas
Matt
Any ideas
Matt
Ahmidou
Could you try to install this:
http://www.microsoft.com/en-us/download/details.aspx?id=30679
Ahmidou
new update, see the 1st post
Clappy
Ok, installed the latest c++ stuff from that link and it works. I just can't see the brush radius.
Cheers,
Matt
Cheers,
Matt
Ahmidou
Do you mean that you don't see the brush disk at all?
Clappy
Ok - after a restart I can see the brush disk. Great work!
Clappy
One suggestion that comes to mind, it would be super awesome if this was merged with the tweek tool. The less switching back and forth the better. But I am sure this would not be easy task.
Cheers,
Matt
Cheers,
Matt
Ahmidou
Actually, it's not possible, I can't interfer or add things to the existing factory tools
May I ask how did you solve undo problem? I'm in same position, that is for particle brush plugin I set iceattribute values and obviously undo doesn't work. Do you save pointposition array in some backup array and save it somewhere when tool exits?
Ahmidou
Sure, here it is:
https://www.si-community.com/forum/v ... 005#p33005
d-e-a-n
Great plugin!
Something like the maya sculpt feature, especially the smooth/relax brush is missing for too long in softimage, so this is awesome, thanks man!
Maybe any updates on the missing symmetry feature?
Lord Futzi Voldemort
This is exactly what I needed right now. Thanks for this plugin. The ALT LMB option would interfere with ALT navigation. If only everyone could leave the ALT key alone... ;)
rnk
this is really great!
i get an error when exiting the tool. not sure if the red circle should show the opacity, but it always stays the same size. and the tool seems the disappear randomly and not showing up when the mouse is over the mesh. is this happening to anyone else? or am i missing something?
thanks!
thanks!
Ahmidou
Hi rnk,
Could you send me you mesh so I can have a look?
A.
A.
