Yes it works on 64 bit. But keep in mind that it uses the push deformer to make the thickness.
So you could replace the push deformer later on with the "move normal add on" (sry don´t have the link yet) to get a "correct" result.
Its a bit like doing it by hand but at least it saves you from copying polys to close the other side,...when you use the thickness addon first then replace "push" with move normal.
how to give a thickness to a poly in XSI
Firebird
Re: how to give a thickness to a poly in XSI
Am I really the only one who knows how to Google stuff?Firebird wrote:So you could replace the push deformer later on with the "move normal add on" (sry don´t have the link yet)
Get it here: MoveNormal
Firebird
agrmrs
hi friends i upgraded my system to 64bit today
now gonna install all the softwares with dirvers
ohh thanx firebird
...... u mean there's a bad influence in push deformer ?
thanx Hirazi Blue i downloaded ur link ;;)
thanx origin for his support too
ohh thanx firebird
