Yes, as I expected. VBScript is not working on your system. You'll never run Softimage until you fix that.hardgore wrote:now i see thisxsisupport wrote:Looks to me like a problem with VBScript on your system, so you may have been right about a missing registry entry. It's not a missing Softimage entry, but a missing VBScript entry (see the comments on that post I linked to).
Try running some VBScript on your system:
echo Wscript.echo "My very first script." > %TEMP%\test.vbs
cscript %TEMP%\test.vbs
softimage does not open
Re: softimage does not open
hardgore
then where do i get the windows script 5.6 ?Hirazi Blue wrote:I think the solution is on this page (from xsisupports blog). But finding the Windows Script 5.6 download might be a bit harder as the international Microsoft site seems to have taken them offline.
Here's a possible solution.
hardgore
i couldnt find the registry..xsisupport wrote:Here's a possible solution.
HKCR\CLSID\{B54F3741-5B07-11cf-A4B0-00AA004A55E8}\InprocServer32
and im reading comments
Look under
Computer\HKEY_CLASSES_ROOT\CLSID\{B54F3741-5B07-11cf-A4B0-00AA004A55E8}
This might help also: sfc -scannow
Or an ordinary System Restore.
It would however be wise to look at your currently installed software to see
what could be causing this, to prevent it from happening again...
hardgore
hardgore
i have read the sss forum and i agree avast is the suspectHirazi Blue wrote:This might help also: sfc -scannow
@hardgore
backup your registry before you do any modification to it (better be safe than sorry)
Expend the regedit list to find the proper list entry ImprocServer32. It look like you are trying to modify the top entry. See my screen grab for reference.
make sure you have the administrator rights to edit the registry (if you read some of the comments from xsisupport link they point to how to do it). If you are not in administrator mode or the administrator, you will be denied any modification.
Dan
Dan
hardgore
like this?Daniel Brassard wrote:@hardgore
Dan
but still doesnt work...
after the change, have you rebooted?
can you check in the directory if the file vbscript.dll exist?
hardgore
yea i saw jscript and vbscript dlls in system32Daniel Brassard wrote:after the change, have you rebooted?
i rebooted but still doesnt work
Now redo XSISupport startup crash test and post a screen grab.
Try this as well:
http://xsisupport.com/2009/04/21/the-ca ... -vbscript/
And don't forget the runonce
http://xsisupport.com/2011/12/01/troubl ... nonce-bat/
Try this as well:
Did you uninstall Avast. Apparently it has a feature called "script shield" which may be preventing you from fixing the problem.
hardgore
i erase avast very long time ago and wont be on my computer foreverluceric wrote:Did you uninstall Avast. Apparently it has a feature called "script shield" which may be preventing you from fixing the problem.
Did you try one of these options?Hirazi Blue wrote:This might help also: sfc -scannow
BTW: Am I correct that you're on a 64 bit machine?
