Normal / Bump Replacement
Falam
Re: Normal / Bump Replacement
Post by Falam » 25 Feb 2013, 22:40
grahamef wrote:
Falam wrote:
BenR wrote:Sorry, that shader is so old that I am not surprised that is not working.
Ben
Someone -- I'm pretty sure it was Daniel Rind -- had a simpler (i.e. non-steep) parallax map shader that was a compound of standard nodes. I believe it was on xsibase but there may still be a copy of it folating around somewhere. In fact I might even have it somewhere among my files.
If you do and it works just as good, I would appreciate it :)
grahamef
Post by grahamef » 25 Feb 2013, 22:43
Falam wrote: If you do and it works just as good, I would appreciate it :)
I edited my previous post -- it's attached there.
Falam
Post by Falam » 25 Feb 2013, 22:52
Thanks, I'll give it a go :) I hope it's better then Bump / Normal mapping :)
Fer
Post by Fer » 01 Apr 2013, 14:25
You have a parallax metaSL shader in the Render tree, last time I tried it, was working OK. But I don't use metaSL too much, it make XSI crash every time. If the developers see this: Please make MetaSL work correctly in Softimage, like mental mill.
