mSymm 2 : Symmetrize Tools
m|Symm2 2.0Author: Martin Yara
Updated September 2014 with support for multiple objects. mSymm2 provides a number of features for modeling with Symmetry: Symmetrize Polygon, Weights and UV with one click Realign points symmetry Select Mirror Components UV Mirroring Subtracts polygons and clusters and merges them back without losing properties.
Download page includes detailed usage instructions (Note: Top of that page is japanese/bottom is english). Introduction available on vimeo - Video of an earlier beta version.
local backup: mSymm.xsiaddon
m|CombineAuthor: Martin Yara
Lets you quickly merge objects while respecting hierarchy and enveloping. Video introduction. Details from the si-community thread (link below):
An update to my old and simple mCombine tool. It merges, reparent, renames, matches center, copy animation, copy envelope, vertex colors, and re-paints weight colors (matching them to their bone color) [..] Custom Preference Menu: You can access this menu through the SI Preferences window, or by pressing ctrl or alt or shift and clicking in "m.Combine Polygons". It now also supports groups, layers and partitions.
You can also use it as a custom command: mCombine ( objects, tolerance, moveCenter, copyAnimation, Gator, ReColor )
Ex: mCombine ( "cube, cube1", 0.1 , true, false, true, true ). It will merge cube with cube1 with a weld tolerance of 0.1, move the center to match cube1 center, it won't copy any animation even if cube1 is animated, it will acquire cube1 properties like envelope and vertex colors through gator and it will re-color points and weight maps to match their deformers wire colors.
local backup: mCombine.xsiaddon
New plugins, tools etc.
gaboraa
Re: mSymm 2 : Symmetrize Tools
Post by gaboraa » 27 Jun 2012, 08:07
BTW I couldn't get mCombine to work, right click didn't give me any option for separating the clusters. Are there some points that I should follow?
myara
Post by myara » 27 Jun 2012, 08:08
mCombine and mSeparate are two different addons.
mCombine:
https://4shared.com/file/Nr4tiv57/mCombinePolygons.html
mSeparate:
https://4shared.com/file/sWp6a7Yz/mSepa ... ygons.html
let me know if you have any problem
M.Yara
Post by Hirazi Blue » 27 Jun 2012, 08:16
myara wrote:let me know if you have any problem
When advertising your own tools, URL tags really come in handy... :D
But aside from that: if you want to ditch your file hoster and would like us to host your plugins please let me know per PM and/or send them with ample description to "upload [at] si-community.com" (no tags, intentionally...)
myara
Post by myara » 27 Jun 2012, 08:23
I always forget that, in my defense, I did use url tags in my previous post :)
And Thanks for the offer :) I'll send you a message in my next release
M.Yara
gaboraa
Post by gaboraa » 27 Jun 2012, 08:45
OK I will test them and if I find some bugs I would inform you, thanks again.
myara
Post by myara » 07 Nov 2013, 10:44
It merges, reparent, renames, matches center, copy animation, copy envelope, vertex colors, and re-paints weight colors (matching them to their bone color). You have 2 options, one with weld tolerance 0.001 and one with 0. You could change the default values by editing the plugin function. Maybe I'll add a custom preference next time.
DOWNLOAD
http://4shared.com/download/YEDOmDFw/mCombine.xsiaddon
M.Yara
julca
Post by julca » 07 Nov 2013, 14:14
Thanks for this tool myara !
I just test it and see you don't take care to Group, Partition and Layer of target object.
Did you plane to "merge" this properties later ?
Cheers.
myara
Post by myara » 07 Nov 2013, 14:19
julca wrote:Thanks for this tool myara !
Cheers.
Thanks for testing it.
I don't use partitions, but groups and layers sounds cool. I'll try to add those features soon. Thanks for your suggestion.
M.Yara
myara
Post by myara » 07 Nov 2013, 16:21
Had a few free minutes so I decided to give it a try, and ended up updating the addon.
Changes:
Tolerance 0 option deleted.
Now you have a custom preferences menu instead. You can access this menu through your Preferences panel or by pressing ctrl or alt or shift and clicking on "m.Combine Polygons"
Groups, Layers and Partitions now supported.
M.Yara
julca
Post by julca » 07 Nov 2013, 17:15
Wouawou ! Ultra fast Update ! :ymhug:
I'll give it a try thanks !
julca
Post by julca » 07 Nov 2013, 17:29
It seems that the Groups doesn't work.
I have 2 objects, one object by group, and after combine them all group are empty.
Otherwise Partitions and Layers works well !
myara
Post by myara » 07 Nov 2013, 18:15
I just checked my code from my iphone. It seems somehow I made an spell miss with groups. I'm quite sure it was working in my prototype snippet, I may have dragged it without noticing it.
Anyway, It's an easy fix so I'll fix it tomorrow when I get to my office.
Thanks for your feedback!
M.Yara
myara
Post by myara » 08 Nov 2013, 04:30
Ok, fixed. Same link
M.Yara
myara
Post by myara » 06 Sep 2014, 09:23
mSymm 2
2.0 final version
After 2 years using it I think it is been quite stable :D
Added multi objects support, fixed some things here and there.
No new features.
Download page
http://skymill.co.jp/wordpress/?jw_port ... mage-msymm
Download ZIP version ( no addon )
http://skymill.co.jp/tools/Softimage/mSymm/mSymm.zip
M.Yara
Post by Bullit » 06 Sep 2014, 14:48
Thanks Yara
