This line should read:
set PYTHONPATH=I add these kinds of lines near the end, but before the line
set XSI_SetenvDone=1;)
set PYTHONPATH=Code: Select all
set XSI_SetenvDone=1thanks a million HiraziHirazi Blue wrote:That is correct: you'll have to add a line to the setenv.bat yourself.
This line should read:followed directly (no spaces) by the path you want to use as PYTHONPATHCode: Select all
set PYTHONPATH=
I add these kinds of lines near the end, but before the linebut that might just be superstition...Code: Select all
thanks any wayHirazi Blue wrote:Yes, it would. You'd probaby just have to append the other paths, delimited by a semi-colon... (I haven't tried this yet, as it hasn't come up yet). IIRC GEAR so far is the only tool for Softimage I found that explicitly asks to set the PYTHONPATH (but I haven't tried all tools, obviously - and my memory isn't all that great either)
