Softimage Nvidia Flex
Flex to SiAuthor: mr_alca @si-community
updated March 2023 — (from the zip's readme) Flex to Si is a connector to Flex (NVidia's hardware accelerated physics framework). Not all flex features are enabled, only calculation of fluids and their collision with static and dynamic geometry.
Installation : put in the same directory e.g. c:\Users\alex\Autodesk\Softimage_2015_R2-SP2\Application\Plugins\nt-x86-64\flextest\ Needs DirectX!!!
Configurable parameters include (see the archive readme for some more explanation): Fluid Mode, Max Particles, Substeps, NumIterations, Speed, Max Particle Speed, Fluid Resolution Multiplier, Fluid resolution, Collision distance, Rest offset, Shape collision margin, Particle collision margin, World Gravity, Adhesion Strength, Cohesion Force, Surface Tension, Viscosity, Vorticity, Dynamic Friction, Static Friction, Particle Friction, Drag, Lift, Damping, Static triangle mesh, Static SDF mesh, Kinematic substeps, Kinematic triangle mesh, Plane Null, Use Ground Plane.
local backup: flex_to_xsi_2.06_1_17_2023.zip
Comments on work in progress
mr_alca
Re: Softimage Nvidia Flex
Post by mr_alca » 22 Mar 2023, 08:38
Flex_To_Si_2.05 uses NVIDIA Flex version - 1.1.0
Flex_To_Si_2.06 uses NVIDIA Flex version - 1.2.0
I didn't notice any difference in their work
flex_to_xsi_2.06_1_17_2023.zip:
Post by rray » 22 Mar 2023, 11:14
xsisoft wrote: 05 Jul 2020, 10:06 checked -link to download working (скачать всё)
rray upload it to resources sections
done ;)
Thanks for releasing this!
Pedrito
Post by Pedrito » 28 Jun 2023, 18:05
Hi there, i have updated the PcTools repo to have the compiled Flex nodes for ICE and the sample scenes. no source code.
It should work, but honestly didnt try it since long time ago, just in case some one is interested here it is:
https://github.com/pedroCabrera/pcTools_Softimage
I updated the repo to have the dlls and sample scenes.
....rest in peace xSI..... 💚
Post by FXDude » 04 Jul 2023, 20:38
Pedrito wrote: 15 Mar 2018, 21:03 Hi there! I have finished and tested the Skin Setup and it is workig very good :)
Great SkinSliding!
Also with your first iterations we can see that it can not only be good for skin, but also for clothing wrinkles !
( later iterations indeed look more like sliding skin )
Because ALOT of clothing sim often only need the wrinkling and not necessarily always alot of cloth dynamics.
Or maybe is it like all one of the same with Flex ?
Otherwise ... still can't wait to try it lol.
grifgont
Post by grifgont » 22 Jul 2023, 23:54
Hello Pedrito!
Thanks for your work.
Unfortunaly It can`t load sample flex scenes from pcTools due to Invalid PC_flex.dll. How to fix it?
Pedrito
Post by Pedrito » 25 Jul 2023, 10:53
Hi there! Im not sure about this, just make sure you have cuda compatible card, drivers and all that, also maybe go to the oficial repo of FLEX and try to run their standalone software and lets see if that one works...
grifgont
Post by grifgont » 27 Jul 2023, 08:15
Pedrito wrote: 25 Jul 2023, 10:53 Hi there! Im not sure about this, just make sure you have cuda compatible card, drivers and all that, also maybe go to the oficial repo of FLEX and try to run their standalone software and lets see if that one works...
Thank you for answer. I have a cuda-compatible card (rtx3070) with a latest drivers. Flex demo from repo works fine.
Post by opoppopopp » 27 Jul 2023, 16:43
grifgont wrote: 27 Jul 2023, 08:15
Maybe Dependency Walker (depends.exe) will help you identify the missing library.
Post by FXDude » 27 Jul 2023, 22:04
Just to say that I ran into the same issue, but got it to work ,
and the following was what I did ::
- I uninstalled/deleted any previous Flex related addons / dlls
- Copied extra files and overwritten existing DLLs from the previous Flex implementation called "Flex_To_Si_2.05.zip"
to the uncompressed "PCTools" folder, in "pcTools_Softimage\Application\Plugins\bin\nt-x86-64"
( in case there was some library missing or something,
while overwriting existing files ... as common files had exactly the same sizes, so were probably the same anyway, but in case that made a difference )
- and then moved PCtools folder in my user "Addons" folder,
So I don't know exactly what made it work among that, but it did !
Post by FXDude » 28 Jul 2023, 21:13
Hi!
I just put together a video-montage of most of the FLEX Sample Scenes
I didn't change anything in these scenes, except for default viewport antialiasing in HQV,
& some realtime shading tweaks to make it easier to visualize volumes,
relative to the previous "solid mass" constant shading.
and the framerates are shown at the bottom ...
( Flex is superfast lol ... or any of this at this detail level can easily involve 10 second+ long "renders",
if not minutes per frame to output cache files )
Otherwise the "CREATURE_TEST_V2.scn" sliding skin scene isn't shown, as I couldn't get it to update the deformed mesh for some reason,
no red ICE nodes or error messages, the output mesh just isn't updating, but haven't investigated anything yet, if you want to have a go at it.
Also if you want, here is a link to the shown "Viz Optimized" scenes :: FlexScenes_Viz.zip
( direct link - 12mb )
And let me know if still getting any install issues,
& Cheers !
:ymcowboy: ~o) *-:)
grifgont
Post by grifgont » 30 Jul 2023, 11:00
FXDude wrote: 27 Jul 2023, 22:04 Just to say that I ran into the same issue, but got it to work ,
Thank you!
flex_to_xsi_2.06_1_17_2023.zip is replaced by PCtools?
I install flex_to_xsi_2.06_1_17_2023.zip first using instruction in archive (put in c:\Users\`username`\Autodesk\Softimage_2015_SP1\Application\Plugins\nt-x86-64\flextest\)
Then I unarchive pcTools_Softimage-master.zip from the github to c:\Users\`username`\Autodesk\Softimage_2015_SP1\Addons\
I trying to put unarchived pcTools_Softimage-master.zip to "pcTools_Softimage\Application\Plugins\bin\nt-x86-64" but with no results.
I`m use a Softimage 2015 SP1. A Flex plugin works only in SP2?
Post by FXDude » 30 Jul 2023, 18:01
sorry I UNINSTALLED previous flex,
and copied all files from from "Flex_To_Si_2.05.zip"
( there are more DLLs relative to "flex_to_xsi_2.06_1_17_2023.zip", if that made a difference )
to :
C:\Users\User\Autodesk\Softimage_2015_SP2\Addons\pcTools_Softimage-master\Application\Plugins\bin\nt-x86-64
... overriding existing DLLs
( also if that made a difference )
Otherwise, what is your GPU ?
grifgont
Post by grifgont » 30 Jul 2023, 19:16
FXDude wrote: 30 Jul 2023, 18:01
to :
Dear FXDude! Thank you very much!
Your installation method works fine!
Post by FXDude » 30 Jul 2023, 20:48
Cool : ) :ymsmug: :-bd
:ymcowboy: ~o)
mr_alca
Post by mr_alca » 03 Aug 2023, 20:42
I tried this installation method, I succeeded. I also realized that PCTools is not compatible with my Flex_To_Si_2.05 plugin, but everything works perfectly when with the flex_to_xsi_2.06 plugin version.
Post by FXDude » 04 Aug 2023, 16:32
mr_alca wrote: 03 Aug 2023, 20:42 I tried this installation method, I succeeded. I also realized that PCTools is not compatible with my Flex_To_Si_2.05 plugin, but everything works perfectly when with the flex_to_xsi_2.06 plugin version.
Good to know! and maybe would it make the "skin sliding" scene work (?) it may also be better to not override DLLs, and just add any files that weren't there from 2.06
