avalon_70
Post by avalon_70 » 20 May 2022, 10:28
Even though we are literally 4 cats, here is version 12 of my material.
I changed the internal order between refraction and reflections, added transparency to translucency, and put a minimum limit on that of refraction.
I added the diffraction.
Alex
avalon_70
Post by avalon_70 » 25 May 2022, 17:29
Latest version.
I stop here.
Fixed a bug (my fault) on reflection, added subsurface scattering, and added global illumination color control.
SPJ
Post by SPJ » 28 May 2022, 14:12
Thanks for sharing avalon_70. I haven't had an opportunity to try it out but look forward to giving it a go!
Post by opoppopopp » 02 Sep 2022, 18:47
Seems Model instance with other Model's instance, i.e. more than one level of instance, won't render?
Follow picture explain it better:
Notice the poly "cube" in "B_Instance" is correct, but "A_Instance1" isn't.
Post by Shekn » 03 Sep 2022, 05:14
Yes, you are right, it does not work. I think that the whole logic of the scene parsing in the Sycles should be changed. I will plan it.
Post by opoppopopp » 03 Sep 2022, 16:24
Thanks !!
BTW. Is Clone/Instance really have benefits in Sycles?
Cycle has any instancing feature or Sycles just raw export them as individual polygon.
Better/even Controllable scene cache will always be best, so greedy because I really rely on Sycles to do my daily work ;)
Post by Shekn » 04 Sep 2022, 04:19
In Sycles cloned and instanced objects renders as instances. Mesh data exports once and then all cloned objects use this data in the render engine. About the bug, I understand the problem and this problem is solvable, but i don't know when.
Maximus
Post by Maximus » 04 Oct 2022, 19:51
hey shekn is it possible to update it to the latest version? can you setup some paypal or donate we can pay you and contribute?
Post by opoppopopp » 04 Oct 2022, 21:17
Guess we are not loss that much feature, since the latest Sycles (03.2022)
because Seems recently, Cycles mainly is busy on support all the GPU vendor's proprietary API :)
Post by Shekn » 05 Oct 2022, 12:50
Every morning I think that I should start to update the Sycles. And every evening I understand that there are too many started projects to support all of them. At the next update I plan to rewrite all from scratch, because the current code is terrible and it's very hard to add new features or fix bags. And this is one of the reasons why I shift the start of the project for tomorrow. Every day. But I will start it, I think.
I3D
Skype: ironic3d
Post by I3D » 05 Oct 2022, 23:36
We can help with the motivational kick, what can we do to help? :)
Post by wireframex » 06 Oct 2022, 16:24
I3D wrote: 05 Oct 2022, 23:36 We can help with the motivational kick, what can we do to help? :)
:ymapplause:
avalon_70
Post by avalon_70 » 07 Oct 2022, 14:33
wireframex wrote: 06 Oct 2022, 16:24
:ymapplause:
:ymapplause:
I3D
Skype: ironic3d
Post by I3D » 07 Oct 2022, 14:50
avalon_70 wrote: 07 Oct 2022, 14:33
:ymapplause:
:ymapplause:
:ymapplause:
gaboraa
Post by gaboraa » 10 Oct 2022, 06:46
I3D wrote: 07 Oct 2022, 14:50
:ymapplause:
:ymapplause:
:ymapplause:
:ymapplause:
I3D
Skype: ironic3d
Post by I3D » 10 Oct 2022, 08:17
I hope that is enough motivation @shekn :)
