Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
avalon_70
Even though we are literally 4 cats, here is version 12 of my material.
I changed the internal order between refraction and reflections, added transparency to translucency, and put a minimum limit on that of refraction.
I added the diffraction.
Alex
Alex
avalon_70
Latest version.
I stop here.
Fixed a bug (my fault) on reflection, added subsurface scattering, and added global illumination color control.
I stop here.
SPJ
Thanks for sharing avalon_70. I haven't had an opportunity to try it out but look forward to giving it a go!
Seems Model instance with other Model's instance, i.e. more than one level of instance, won't render?
Follow picture explain it better:
Notice the poly "cube" in "B_Instance" is correct, but "A_Instance1" isn't.
Yes, you are right, it does not work. I think that the whole logic of the scene parsing in the Sycles should be changed. I will plan it.
Thanks !!
BTW. Is Clone/Instance really have benefits in Sycles?
Cycle has any instancing feature or Sycles just raw export them as individual polygon.
Better/even Controllable scene cache will always be best, so greedy because I really rely on Sycles to do my daily work
In Sycles cloned and instanced objects renders as instances. Mesh data exports once and then all cloned objects use this data in the render engine. About the bug, I understand the problem and this problem is solvable, but i don't know when.
Maximus
hey shekn is it possible to update it to the latest version? can you setup some paypal or donate we can pay you and contribute?
Guess we are not loss that much feature, since the latest Sycles (03.2022)
because Seems recently, Cycles mainly is busy on support all the GPU vendor's proprietary API
Every morning I think that I should start to update the Sycles. And every evening I understand that there are too many started projects to support all of them. At the next update I plan to rewrite all from scratch, because the current code is terrible and it's very hard to add new features or fix bags. And this is one of the reasons why I shift the start of the project for tomorrow. Every day. But I will start it, I think.
I3D
- Skype: ironic3d
We can help with the motivational kick, what can we do to help?
avalon_70
I3D
- Skype: ironic3d
gaboraa
I3D
- Skype: ironic3d
I hope that is enough motivation @shekn
