Post by Shekn » 17 Mar 2022, 05:42
It is very sad, but I can not reproduce the bug.
The system of color correction works in the following way: after each render session the system save the raw pixels of the output image without any color correction. Then, when render settings is changed, the system looks, may be the user change only color correction settings. If so, then it does not start new render, but use previously saved pixels, apply correction with selected parameters and output the image to the screen. So, at each render call, the system can make actual render or reuse the result of the previous render. If in the console log there is a string with render time, then the system make actual render and remember raw image, if nothing appear, then it reuse the image, remembered in the previous render call.
May be your bag can be fixed by simply re-rendering the scene. The system save proper raw pixels, and all will works fine.
What vesion of the Softimage you use? The icon is not the same as on 2015 version. May be this is the reason?
I3D
Skype: ironic3d
Post by I3D » 17 Mar 2022, 07:38
Thanks Shekn
I am using 2015 SP2, the icon was changed manually through a downloaded package from the resources section in this site, it's called XSI Essential package (kind of FU for Autodesk).
That is strange, the old version 1.11 doesn't give me this grief at all. I actually noticed it first by opening a scene saved with 1.11, the result was a kaleidoscope. The I'll show you.
Here is the original:
Here is the same scene opened in 1.12 (it's not apparent when it finally renders, but there are smudges on the walls, Check the video below this image to see what I mean how the render starts)
The video of how the render starts and progress is below, I've never seen this behavior before!
And here is the scene file if you want to check it for yourself:
sirdavid32
Post by sirdavid32 » 18 Mar 2022, 00:55
Thank you, Shekn, for this outstanding update!
I can't imagine all the hours that go behind keeping up SYCLES alive.
Thank you, sir.
Post by Shekn » 18 Mar 2022, 06:26
I3D
I think, that the problem in the following. Version 1.12 have some new parameters, which does not exists in previous 1.11. When you open the scene, saved in the previous version of the render, then it use old set of render settings. You can not tweak new settings, because it does not show in UI (this is common behaviour of the Softimage). So, when you start the render, it use default (and may be non-initialized) values of new parameters, and as a result produce wrong image. These parameter values may be nonsensical for the renderer. What you show on the video is close to effect of the "Scrambling distance" parameter.
Solution: merge old scene to the new empty scene and setup render settings from scratch. All should works.
SPJ
Post by SPJ » 01 Apr 2022, 17:26
Thanks for the update on Sycles! So pleased to report I can successfully get GPU render from my Radeon 5700XT for the first time. Haven't done any benchmark testing yet to see how much improvement it has made to render time, but it should be significant!
Really appreciate the work you are doing to implement cycles into SI!
SPJ
Post by SPJ » 15 Apr 2022, 22:32
Quick question to see if anyone has worked with equirectangular (360) rendering using Sycles?
I've been using a lens shader for Mental Ray which works well, but obviously won't work with Sycles render engine. It looks like Cycles in Blender uses a 360 camera object in the scene, but I haven't found a Sycles equivalent.
Post by Shekn » 16 Apr 2022, 06:07
Select the camera object (not the root null), add CyclesCamera property (by Property - Cycles Properties - Add Camera Property), switch camera type to Panorama. Then you will be able to select different modes of the panorama camera, tweak parameters and so on.
SPJ
Post by SPJ » 16 Apr 2022, 14:13
Amazing! Will check that out, thanks.
Surface_VR
Post by Surface_VR » 23 Apr 2022, 09:43
Thank you Shekn for the update on Sycle.
I did a render test of the same Scene.
The render time in 1_11_1 was 2 hours, but in 1_12 it was 1 hour 23 minutes,
And with the GPU on, it took 37 minutes! This is amazing!
But VDB is a little different from the previous render results, image attached
To make the detail closer to the previous 1_11_1, I left Passes blank in the Denoising tab of the Render Options and VDB produced the desired result.
However, the detail on other objects will be a bit lower quality.
1). 1_11_1
2). 1_12 - Merge. (1_11_1 to a new Scene)
3). 1_12 - Merge. (1_11_1 to a new Scene) Passes blank in the Denoising tab of the Render Options
4). 1_12 - New Scene. (Rebuilt the Scene from scratch.)
5). 1_12 - New Scene. Passes blank in the Denoising tab of the Render Options
Or does this mean that 1_12 is rendering the VDB in finer detail?
I3D
Skype: ironic3d
Post by I3D » 23 Apr 2022, 09:53
Hey Shekn
I'm experiencing banding in lots of areas with Sycles, even when rendering directly to EXR. When previewing of course they are more apparent, less apparent in Final render but they are there. So any These are mostly apparent in dark areas. Any idea how to remove them?
The image below is a full float EXR exported to PNG, notice the banding in the dark areas, any color correction make it worse.
And this is a direct render to PNG from XSI
Post by Shekn » 24 Apr 2022, 06:19
Surface_VR
It's possible that render result is slightly different in different versions of the render. This is because Cycles developers tweak different aspects of the renderer. In particular vdb rendering. All your images looks correct and I can not see any artefacts or something similar.
I3D
I don't fully understand the problem. The first image is rendered into exr and then converted into png in external application, right? Is it one image with background or two images (object and backround in separate files and then composed in an application)? I make simple test with motion blurred sphere over non-transparent background, render it into exr and png. After converting exr into png in Photoshop (using simple Exposure and Gamma method) the results are identical.
Surface_VR
Post by Surface_VR » 24 Apr 2022, 12:52
Thanks Shekn!
avalon_70
Post by avalon_70 » 14 May 2022, 05:54
Hello everyone and especially "Shekn" who is doing a fantastic job!
In my own small way I want to contribute.
I created an Architectural Material, similar to that of Softimage.
I state that I am just a 3D graphics Design, so what I have done is limited to the use of shader nodes.
For example, I had to contend with the fact that most cycle's shaders don't return RGB once inside a compound, and for this I lost long time for resolve it.
Short explanation. Practically it follows the original Architectural Material, these are the differences:
All colors (except Diffuse) have a "Weight" parameter (Redshift style);
All colors have a "Gamma" parameter, which is needed once set to 2.2 to have perfect correspondence between the shader color and the render (Redshift style, put on my request, obviously done better and in the render panel, when I was beta testing) ;
I had to put the "Fresnel" parameter inside the reflections as "Weight" because I don't know how to put a Boolean check (if anyone knows how, please tell me how to do it).
Hope you like it.
Alessandro (Alex)
Surface_VR
Post by Surface_VR » 14 May 2022, 13:23
Nice!
Switch in Cycles is still a numerical input as far as I know, so I think Weight is the right choice!
avalon_70
Post by avalon_70 » 16 May 2022, 07:51
Surface_VR wrote: 14 May 2022, 13:23 Nice!
good to know!
I edited the material by fixing the shadow bug which has cycles with transparent objects (crazy!).
I have currently used the usual transparent shader with the light path, which works but does not read refraction (edges, folds etc.).
I haven't found any source on how to get around it, if anyone knows, please come forward :).
I3D
Skype: ironic3d
Post by I3D » 17 May 2022, 02:21
Awesome, thanks avalon_70
