Bennyhase
Post by Bennyhase » 08 May 2020, 13:26
Hello Shekn, here is a youtube video that i´ve made a few minutes ago. Please note: no matter what i´m doing inside softimage (edit Material values or edit light values or doing some translation of objects or setting texture coordinates or set rendersettings), after one or 2 minutes i can´t render anymore on GPU. CPU will work, but i want to have GPU. I have to restart XSI. This effect will happen randomly.
Post by Shekn » 09 May 2020, 06:11
It seems, like the problem not on my side, but on the Cycles side. You can try to reproduce this bug on the Blender. I can't do this myself, because with my gpu-s all works fine. Make the similar scene and render image several times. There are no guarantee, that this bug will be reproduced. It depends on the version of the Blender. And may be the reasons of it already fixed.
sirdavid32
Post by sirdavid32 » 09 May 2020, 21:10
This is called "bucket fight". All GPU's are trying to get their neighbor's buckets. I don't know about progressive. Try each GPU pair name. Not all of them at once. And try 32x32 tile size bucket.
This term was explained by one of the top GPU guru's render farms in the world when we went "technical" a few months' back for a render project I had.
Bennyhase
Post by Bennyhase » 11 May 2020, 07:11
Thanks, will try it
Bennyhase
Post by Bennyhase » 11 May 2020, 16:09
Question A: no light excluding possible (light linking) to exclude lights from specific objects ?
Question B: i want to try exact setup for Fog like in this video at Min 17:50: , but can´t conncect Shaders with Volume nodes and a mix node to the Volume-Shader-Port of XSI. Bug ? (try to reproduce same setup in the Video for Blender)
Surface_VR
Post by Surface_VR » 12 May 2020, 05:00
First of all, thank you for this wonderful plugin
I have the same symptom, and I can't insert "Emission" or "Transparent" into the volume port like Blender.
However, you can avoid it by putting it in the compound. If you load the scene after saving it, it may get out of the port.
Post by Shekn » 12 May 2020, 08:38
Answer to the question A: it is impossible. But of course, it is possible by using composition.
Answer to the question B: it is not a bug, it is feature. There are some conceptual difference between Softimage and Blender. In Blender you can connect every node's port to every other node's port (for example, scalar output of the one node to color input of the other node). But in Softimage you can connect only port with the same type. The same true for nodes and ports in the main material shader node. cycVolumeScatter node is a node for volumes, cycTransparent node is a node for surfaces. That's why you can not connect volume output to the surface input and vice verse. Softimage watching you and can not allow you to connect nodes with different context.
In any case, there are possibility to define shader node as node with several contexts, and then Softimage will allow to connect it to surface and to volumes. I will add this.
Also remember, that on the video, the author split position vector and use z-coordinate in the shader. In Softimage up axis is Y, so you should use the y-coordinate of the position value.
Post by opoppopopp » 12 May 2020, 12:51
Bennyhase wrote: 11 May 2020, 16:09 Question A: no light excluding possible (light linking) to exclude lights from specific objects ?
As you can see in the previous post in this thread, seem no light exclude here, and It seems blender can't do light exclude either?
Post by opoppopopp » 12 May 2020, 12:52
Shekn wrote: 12 May 2020, 08:38 Answer to the question B: it is not a bug, it is feature. There are some conceptual difference between Softimage and Blender. In Blender you can connect every node's port to every other node's port (for example, scalar output of the one node to color input of the other node). But in Softimage you can connect only port with the same type. The same true for nodes and ports in the main material shader node. cycVolumeScatter node is a node for volumes, cycTransparent node is a node for surfaces. That's why you can not connect volume output to the surface input and vice verse. Softimage watching you and can not allow you to connect nodes with different context.
I vote for keep this strict typed :)
Post by Shekn » 13 May 2020, 05:01
Type of the data and context of the data are different concepts. Link in ICE, you can not connect scalar port with context per-point to scalar port with context per-object. In Render Tree by default you can not connect color port with context Surface to color port with context Volume. In ICE this separation have the sense, because data with different contexts processes in the different way. But in Render Tree this difference is more ephemeral. For shader calculations there are no difference between different contexts.
Bennyhase
Post by Bennyhase » 13 May 2020, 07:40
Thanks for the tips
Post by opoppopopp » 13 May 2020, 14:09
Shekn wrote: 13 May 2020, 05:01 Type of the data and context of the data are different concepts. Link in ICE, you can not connect scalar port with context per-point to scalar port with context per-object. In Render Tree by default you can not connect color port with context Surface to color port with context Volume. In ICE this separation have the sense, because data with different contexts processes in the different way. But in Render Tree this difference is more ephemeral. For shader calculations there are no difference between different contexts.
Make sense, and I understand now ^:)^
"In ICE this separation have the sense..., But in Render Tree..."
Post by Shekn » 14 May 2020, 12:39
Small update 1.9.1. Download here: https://ssoftadd.github.io/syclesPage.html
Nothing new, only some bugfixes and improvements. In particular, fix the bug with osl-shaders. Now SToon should works. For reliability it's better also to delete all *.oso files in the folder with the addon. When Cycles use the osl-shader at the first time, it compiles it to the corresponding oso-file. Some times ago Blender developers upgrade the version of the osl-compiler, and that's why all compiled shaders should be recompile. However, in principle, all should works without any such updates.
Surface_VR
Post by Surface_VR » 14 May 2020, 14:41
Nice update!
I will ask you a question
I want to do photoreal HDRI mapping
Even if you use HDRMaster etc., the rendered image is basically blue and dark
Also, I think that the method of connecting cycMath to the Background strength of light as often as in the Blender tutorial is different in Cycles.
Is it possible to turn on World's Multiple Importance which is a function of Blender in Sycles like the video below?
Bennyhase
Post by Bennyhase » 14 May 2020, 15:03
Thanks Shekn. SToon works now :-)))
Post by Shekn » 14 May 2020, 15:31
Surface_VR where is this parameter in the Blender 2.8x? I can't find it. There is something similar in World Properties - Settings - Surface, but Sampling method does not change anything in the rendertime or noise quality.
