Making a hotkey for tools with a picker
Talik
Skype: nihao00042
Post by Talik » 10 Sep 2025, 10:49
Hi guys. I want to make hotkey for "Extrusion along curve" command. But the script code cannot be used to create a button. This happens always when I try to make a button for a tool that needs to select an object in viewpport. What am I dong wrong?
Code
Re: Making a hotkey for tools with a picker
Post by opoppopopp » 10 Sep 2025, 17:26
So why not just set a hot key for that tool?
Talik
Skype: nihao00042
Post by Talik » 10 Sep 2025, 19:56
opoppopopp wrote: 10 Sep 2025, 17:26 So why not just set a hot key for that tool?
That's not this command. I need to extrude nurbs circle along the curve
Kolya
Post by Kolya » 11 Sep 2025, 11:03
var oList = GetValue("SelectionList");
if(oList.Count !== 0)oList = oList.Filter("crvlist");
//oList.Unique = true;//optional to keep only unique objects
var objectsNeeded = 2;
while(oList.Count < objectsNeeded){
	var pick2 = PickElement(siCurveFilter);
	if(pick2(0) == 0)break;//pick cancelled
	oList.Add(pick2(2))
if(oList.Count >= 2){
	var op = ApplyGenOp("Extrusion", "MeshSurface", oList);
	InspectObj(op);
Post by opoppopopp » 11 Sep 2025, 16:54
Then search for 'Power Extrude' at resource section.
It cover all you need, and way more robust than re-write everything your self.
