Vray renderring with standard cam
julius
Post by julius » 31 May 2013, 23:56
Hi all,
I try to render some frames with Vray and a plugin that allows me to render only with a standard camera, and not with the Vray physical one.
The problem is that when I render, the resulted picture is not the same than the one I have in my camera. I verified pict ratio etc... but all is ok.
When I switch to mental ray renderer, the problem is immediatly solved.
It seems that Vray apply something to the standard cam, but what is it ?
Can you help me ?
julius
Re: Vray renderring with standard cam
Post by julius » 01 Jun 2013, 09:46
ok, I found my error : I didn't check "pick FOV from camera" in the Vray physical cam lens shader.
Problem solved.
