procedural sunflower creation in ICE tutorial part 1
nikaragua86
Post by nikaragua86 » 05 Jan 2013, 14:18
Matic
Re: procedural sunflower creation in ICE tutorial part 1
Post by Matic » 07 Jan 2013, 21:55
Enjoyed this, thanks for sharing it!
TwinSnakes007
Post by TwinSnakes007 » 07 Jan 2013, 22:26
How is part 2 coming along?
nikaragua86
Post by nikaragua86 » 08 Jan 2013, 21:59
little bit later )))
dwigfor
Post by dwigfor » 08 Jan 2013, 23:56
I also enjoyed this. Nice application of math for real world phenomenon. I have a suggestion, though. I think you'll get better performance if you use Array rather than repeat node. Try using Build Array from Constant ->Add Point (Positions), and then use the sub indexes of that array instead of the Repeat Counter. Finally, you'll plug this into a Set Point Position, instead of the add point (positions). Saw a big slowdown when you increased it from 100 to 500, and I think this will help with that.
nikaragua86
Post by nikaragua86 » 09 Jan 2013, 12:44
hmmmmmm, you`re right. i`ll do it.thank you very much )))
nikaragua86
Post by nikaragua86 » 21 Feb 2013, 00:11
implemented the dwigfor suggestion - got rid of the repeat node
dwigfor
Post by dwigfor » 21 Feb 2013, 18:33
Huge speedup! Nice explanation. :)
nikaragua86
Post by nikaragua86 » 21 Feb 2013, 19:55
thanks again )))
