Key Pivot Tool
Key Pivot ToolAuthor: Constantine Tarasenkov
SI has a pivot transformations that can be keyed without using a Center operator. The awkward thing for me is that this is done by changing the parameters values from the ppg window and translation of the pivot happens relatively to local transformation matrix of the object. So I wrote this handy little script that allow you to just pick a position in space that would be a new pivot center of the current frame.
For usage details and downloads, see the si-community thread linked below.
local backup: keyPivotTool.zip
iamVFX
Key Pivot Tool
Post by iamVFX » 08 Mar 2012, 22:22
xsi = Application
frame = xsi.GetValue("PlayControl.Current")
pivot = xsi.PickPosition("Set new pivot position and key it", "Remove key on the current frame")
if pivot[0] == 1:
	v3 = XSIMath.CreateVector3(pivot[1],pivot[2],pivot[3])
	m4x4 = XSIMath.CreateMatrix4()
	obj = xsi.Selection[0]
	obj.Kinematics.Global.Transform.GetMatrix4(m4x4)
	m4x4.Invert(m4x4)
	v3.MulByMatrix4InPlace(m4x4)
	x, y, z = 0, 0, 0
	x, y, z = v3.Get(x, y, z)
	xsi.SetValue("*.kine.local.pposx", x)
	xsi.SetValue("*.kine.local.pposy", y)
	xsi.SetValue("*.kine.local.pposz", z)
	xsi.SavePivotKey(["*"], "siTrn", frame)
	xsi.RotationTool()
elif pivot[0] == 2:
	try:
		xsi.RemoveKey("*.kine.local.pposx,*.kine.local.pposy,*.kine.local.pposz,*.kine.local.pcposx,*.kine.local.pcposy,*.kine.local.pcposz", frame)
	except:
		pass
myara
Re: Key Pivot Tool
Post by myara » 23 Mar 2012, 06:48
Softimage has an unbinded command in the Keyboard Mapping that let's you move the pivot.
It's called Edit Transform Tool Pivot in the Transform Tool group.
There is also a Transform Tool Pivot(alternate), but It seems to do the same.
M.Yara
iamVFX
Re: Key Pivot Tool
Post by iamVFX » 23 Mar 2012, 16:13
Edit Transform Tool Pivot is a temporary way to move pivot position (same as holding ALT button). My script works directly with pivot kinematic values under local transforms of the object and key them for animation purposes (imagine a rolling cube, for example, which changes its point of rotation with time)
myara
Re: Key Pivot Tool
Post by myara » 24 Mar 2012, 08:01
Oh , now I get it!!
Nice tool !
M.Yara
Haimund
Re: Key Pivot Tool
Post by Haimund » 06 Jun 2014, 06:11
Hi, this is a great tool. But why it applies to everything in the scene?
Can you help??
