PhysX Fluid Simulation in Softimage ICE
PhysX Fluid Simulation This ICE compound wraps a CUDA implementation of the SPH fluid algorithm and allows
a very fast particle simulation of fluids on NVidia GPUs. A CPU mode is also available;
it is rather fast as well and not limited by the available GPU RAM.
CPU mode can be used as the default mode or as a fallback mode.
See the si-community thread linked below for details and tips on using this compound. Here's a test video by Tekano with 2 million particles.
local backup: Waterfall_FX.rar
Tekano
Re: PhysX Fluid Simulation in Softimage ICE
this looks like a lot of fun, sorry I havnt had time yet to have a go with the new version Oleg, soon I hope!
ChrB
Thanks for this great implementation!
Is it possible to do self collision with eg a box shaped particle?
Christian
Christian
Arnold for the masses!
Mr.Core
- Skype: giga-core
You can easily build an array of topology with cube primitive shape and drive it by particles and "transform topo" node
It really looks amazing! And there are also a couple videos with their RD on GPU cloth with long constraints - also very impressive stuff and I hope they will add it soon
perryharovas
Hi Mr. Core,
Just want you to know what a great plugin this is.
I have one issue though:
I have an nVidia Quadro 600 and a nVida Tesla C2075
As far as I can tell, I should be able to see CUDA, but this error seems to suggest that the plugin
can't see a CUDA card.
Is that what it means? It seems to run fine without the GPU button checked, but as soon as
I check it (or press play on a scene where it is set to use GPU, such as your demo scenes) I get this error.
Maybe I have to update a driver or something?
Any help would be most appreciated!
Perry
Perry
perryharovas
I figured it out, sorry to bother you!
This may help others:
I downloaded the nVidia Maximus Configurator and it helped me to select which card was for graphics and which card was for compute.
Here is the link:
http://www.nvidia.com/object/maximus.html
Thank you again for an amazing plugin!
Perry
Here is the link:
Perry
Just had a chance to try this a bit. Wow! This is great! Now I'll be stuck on it all weekend...
Mr.Core
- Skype: giga-core
@perryharovas
Thanks for confirmation, I was curious that whether it works on quadros and tesla's
Just have to say this is one of the finest SI additions to date. So fast and easy to use! A big thanks to Mr. Core!!!!
gustavoeb
- Skype: gustavoboehs
Anybody got it working with the old gtx 260? Just updated the drivers, but no luck
Gustavo Eggert Boehs
Mine is working on a GTX 285 just fine, I assume they're about the same in function/features. What error are you getting?
caledonian_tartan
it's working on a quadro 4000 over here! and it is fast!
SI 2015 @ WIN7-64
TwinSnakes007
There is not 32bit plugin in the d/l, only 64bit.
From the original post:
as most of the Softimage crowd seems to have turned "64".
Sadly for those still "on 32-bit" this is a limitation you'll encounter often these daysMr.Core wrote:Builded and tested under 2012 sp1, win x64 only.
TwinSnakes007
Well crap, I'm not getting a new system til December.
Oh well, CUDA Bullet will have to do til then.
-TS-
-TS-
gustavoeb
works now!
# INFO : [PX][SPH]: Succefully created PxWorld!
# ERROR : [PX][SPH]: Get CUDA support failed!
# INFO : [PX][SPH]: Created PhysX World!
# INFO : [PX][SPH]: Succefully setted Fluid Attributes
# INFO : [PX][SPH]: ADD STATIC OBSTACLE: STAT OBS ADDED SUCEFULLY!
says it cant get CUDA to cooperate, but it is already significantly faster then Lagoa
TwinSnakes007
Its working for me too...
on 32bit OS!
-TS-
on 32bit OS!
-TS-
