I3D
Skype: ironic3d
Post by I3D » 24 Sep 2026, 21:02
One more thing, can the SToon be updated to work with this version? I know that SToon is mainly OSL, but easy toon crashes the render, so does the line deterministic and every other SToon node.
Post by Shekn » 27 Sep 2026, 11:32
I think not. In the current version of the Cycles render, some OSL commands crash the render. I found that the node CNPRK_Line2.osl uses the command startswith(selfName,"-"), which crashes the render. I don't know why—whether it is a bug or a feature. I mean, maybe the OSL specification has changed, and what was acceptable previously now generates an invalid shader. Some other OSL shaders work well. However, it seems too complicated a task to check all shaders, understand what they should do, and change the code if it crashes the render. I also noticed that the current version of the OSL compiler crashes if the OSL code contains multi-line comments /*...*/. One-line comments are fine. All shaders from SToon have multi-line comments with a copyright notice in the header. This can be easily fixed by removing all these comments (using a simple Python script, which any AI can write).
Post by Maximus » 07 Oct 2026, 07:49
idk what is going on, first time i get this error while installing Scycles.
Anyone had the same? what could have caused it?
Post by Shekn » 09 Oct 2026, 13:26
Hmm, this is my mistake. DLLs that show errors on loading are not required at all. They are debug versions of similar libraries, which are also contained in the bin folder. They are not required for loading SyclesPlugin.dll, so it does not matter whether they are loaded or not. But SyclesPlugin.dll is not loading. So something important is missing. Again... Try this distribution: https://github.com/Tugcga/Sycles/releas ... .4/dll.zip I updated the archive and included some additional DLLs, which should exist on any system, but in some cases they may be missing from Windows. So, delete all external DLLs from the bin/nt-x86-64 folder (except SyclesPlugin.dll and SyclesICENodes.dll) and copy the files from the archive. I hope this helps.
Post by Shekn » 11 Oct 2026, 07:27
Maximus, tell me whether what I wrote helped or not.
I3D
Skype: ironic3d
Post by I3D » 13 Oct 2026, 00:46
Shekn, we're you able to verify the issue with the texture cashing from my previous post?
"I also found a bug, it is related to the new texture cache. By default, before enable or disabling it. Loading an environment light and assigning a texture to it, the results are bad. As you can see in the video. Disabling the texture cache and the environment just works. enabling it again and the environment won't render or contribute to the environment."
thank you
Post by Shekn » 13 Oct 2026, 16:00
I am very sorry, but I completely missed your bug report. I will try to investigate it in more detail.
Post by Shekn » 22 Oct 2026, 04:37
I3D, it looks like the issue depends on your HDR maps, because I fail to reproduce it with my own textures. In any case, it seems like the problem is on the Cycles render side, because the addon does not perform any essential actions with texture caching. It simply pass arguments to the engine, and the renderer does all the work.
