SPJ
Post by SPJ » 06 Apr 2025, 00:05
Is the 2.x.x Sycles only supporting Nvidia GPUs? Anyone using AMD? Can't see my AMD 5700XT or AMD 6900XT as options whereas I could use them with Sycles 1.12. I have had to roll back because the CPU rendering is pretty slow in comparison, but I'm missing some of the updates to shaders etc so really keen to upgrade.
I'm installing the pre-compiled add-on only. I have seen dll files on Github but it seems that they are already in the installation when I look to add them manually. So I'm guessing installing 2.2.1 using normal route in SI 2015 SP2 File -> Addon is all I need to do?
Post by Shekn » 06 Apr 2025, 04:38
May be you should try the 2.1.3 version. As far as I know, no additional tweaks are required other than a simple addon installation. However, I do not have a PC with an AMD GPU, so I cannot test it.
SPJ
Post by SPJ » 06 Apr 2025, 09:00
Thanks Shekn. Very oddly, when I install 2.1.3, the Cycles renderer is not an option in my pass renderer options. It's just Mental Ray, Hardware Renderer etc. This is also the case wth 2.1.2 & 2.1.1.
I have a laptop with GeForce GFX 1050 Ti. I installed 2.1.3 on there and it is working, also with GPU support. I installed 2.2.1 on there, no GPU support. 2.2.0 also no GPU support. That seems to be a problem with other forum folks as well.
But mainly I would like to get the more powerful AMD GPUs working. I don't know why 2.1.3 won't show Cycles option on my main machine Render Manager?
EDIT: Just noticed an error in log "ERROR : 2356 - This plug-in is not installed: Cycles Renderer Options"
Post by Shekn » 07 Apr 2025, 10:23
May be you need to download nvcuda.dll and manually copy it to the addon directory. Like described on Github page (https://github.com/Tugcga/Sycles#how-to-install).
SPJ
Post by SPJ » 10 Apr 2025, 09:13
Yep, that sorted the issue Cycles not showing as renderer option on 2.1.1, 2.1.2 and 2.1.3. Thanks for the guidance.
Unfortunately, the AMD GPUs were not enabled on any of those versions :(
So unless someone else has got AMD GPU working and can say otherwise, it looks like it's not been possible with Sycles v2?
Post by Shekn » 12 Apr 2025, 11:00
Sycles 2.1.3 use Blender sources from January 2023. You can try to download a Blender build from this date and check if your GPU is visible in Blender. If it is not visible, then it cannot be used in Sycles.
SPJ
Post by SPJ » 12 Apr 2025, 22:49
Good idea. I downloaded Blender 3.4 which is Dec 2022 release. Blender 3.5 is March 2023 release so figure the source you used would have been 3.4. Both AMD cards are showing in the HiP options for Cycles rendering.
So I suppose there is some hope, but I don't know how to go about enabling it in XSI.
Post by Shekn » 13 Apr 2025, 12:21
Hmm, I don't know too...
Post by opoppopopp » 13 Apr 2025, 16:46
Let's make it clear, for 2.2+ :
Are there any other people's GPU that can also work?
besides, 2.2+ GPU is working on Shekn's development machine, right? :)
Post by wireframex » 14 Apr 2025, 07:29
Only 2.13 is usable for me.
2.2+ doesn't work on my RTX4090 laptop nor my 2x RTX3090 computer.
Post by Shekn » 18 May 2025, 16:08
It's too late an idea. The render may detect the GPU if you copy the lib folder (with cuda binaries) from the add-on directory into the Softimage system folder (C:\Program Files\Autodesk\Softimage 2015\Application\bin).
Post by wireframex » 18 May 2025, 17:42
Shekn wrote: 18 May 2025, 16:08 It's too late an idea. The render may detect the GPU if you copy the lib folder (with cuda binaries) from the add-on directory into the Softimage system folder (C:\Program Files\Autodesk\Softimage 2015\Application\bin).
YOU'RE A MASTER IT WORKS !!!
All my GPUs are detected now with 2.2.1
only GPU OPTIX doesn't render anything --> I have a black screen
Denoising : OPENIMAGE & OPTIX work very well
Phil
Post by opoppopopp » 18 May 2025, 18:17
Yes, GPUs are detected! \m/ (even with Radeon iGPU, De-noise with OptiX also working) but render region is black :( with only GPU selected.
I must miss some step? I ONLY copy lib folder to 'Application\bin\'
Post by opoppopopp » 18 May 2025, 19:23
@Shekn say COPY, not CUT :)
so GPUs work
but why...(leave "2.2 lib" at system folder, not even conflict with 2.1.3 addon when I test, but 2.2 addon really need "2.2 lib" at both system and addon folder)
Post by opoppopopp » 18 May 2025, 19:44
Is 2.2.1 include the new Volume Scatter Shader?
SPJ
Post by SPJ » 18 May 2025, 22:24
Take a massive bow @Shekn! This has enabled both my AMD GPUs with 2.2.1. It was the missing link and I can't believe I can finally move from Cycles v1. Huge thanks!!
