Post by opoppopopp » 15 Sep 2024, 20:53
Shekn wrote: 23 Jul 2024, 04:15 For detect gpus the renderer use precompiled binaries, which placed inside the folder Sycles\Application\Plugins\lib\ This folder contains many different *.zst files for different gpu models. You can try to download Blender 4.3 and copy these files from the distributive to the folder of the addon. May be it will help.
I test several blender builds(4.0-4.3) and try to copy/use its "Lib" folder, but no luck. (all those blender building's Cycles GPU is working)
Since GPU working on your development machine, so Is it possible that we just simply missing some other dlls? (maybe they looks unrelated, like blender include its own msvcxxx.dll)
Is Cycles SDK and blender have same release cycle? (because I saw a 4.2.0 SDK at https://projects.blender.org/blender/cy ... tag/v4.2.0). Just imagine problem will be magically solved when compile against coming 4.3.x release :D
BTW. How many of us can confirm GPU is working your machine ? (not only shown but also working)
Post by wireframex » 16 Sep 2024, 04:49
I tried many things with dll without success. I returned back to old version.
Post by Shekn » 16 Sep 2024, 12:43
GPU still not working, and I think that it is not related to dll-s inside the distributive. The reason is something else. There are some ideas, but no clear understanding.
I3D
Skype: ironic3d
Post by I3D » 18 Sep 2024, 11:38
Shekn wrote: 16 Sep 2024, 12:43 GPU still not working, and I think that it is not related to dll-s inside the distributive. The reason is something else. There are some ideas, but no clear understanding.
Shekn, not sure if this will help. but Gaffer team recently where able to include the GPU part of cycles into Gaffer in their 1.4.12 release. Perhaps their implementation could hold the answer?
Post by FXDude » 22 Sep 2024, 23:25
just to say, unlike others here, I was able to install Sycles v2.2 no problem,
But it reminded me of trouble I had installing the FXTree denoiser,
and updating my GPU driver solved it.
So perhaps would that solve your issues?
Just in case, my driver version is 546.01
Otherwise particle motion blur works!
but motion blurred particles does slow down rendering considerably,
this medium region was a 3 minute render, relative to less than 10 seconds without MB with the same 8 samples.
So for motion blur, the "pseudo motion-blur" trick I used of duplicating particles along velocity vectors, is MUCH more efficient,
as particle count barely affects render-time.
The following was a mere 16sec with TONS of particles
8 million particles including duplicated along velocity vectors.
( edit: region renders were 16 seconds, this one was 23 seconds @ 1080p )
But if I'm reverting to the previous version, it's mostly about the denoiser indeed not working in 2.2, which is a biggie for me.
Otherwise everything seems great!
HDR render region is also great ! :)
Post by FXDude » 22 Sep 2024, 23:30
FXDude wrote: 22 Sep 2024, 23:25
Just went to the release page,
https://github.com/Tugcga/Sycles/releases
and there's a 2.2.1 release from last week WITH DENOISING !
( will test shortly )
Thank you Shekn ! :ymhug:
I3D
Skype: ironic3d
Post by I3D » 23 Sep 2024, 01:00
Thank you Shekn 🙌
Post by wireframex » 23 Sep 2024, 15:06
No GPU in this last version (2.2.1)
Get back to 2.1.3
I3D
Skype: ironic3d
Post by I3D » 24 Sep 2024, 05:07
I agree with wireframex, no GPU rendering.
Post by opoppopopp » 06 Oct 2024, 22:34
Sycles is faster for real :x
and I will trade GPU for motion blur on points for this sequence.
tarkovsky
Post by tarkovsky » 23 Oct 2024, 09:38
Dipping my feet in Soft again after a long break. So nice... :) Thanks for this amazing plugin - one issue:
Is it me, or doesn't the mesh properties work? If I apply a mesh property and untick visibilities, nothing really happens?
thanks!
Post by Shekn » 23 Oct 2024, 13:06
Yes, your are right. This is an issue. I will track it.
Post by wireframex » 25 Oct 2024, 06:19
Shekn wrote: 23 Oct 2024, 13:06 Yes, your are right. This is an issue. I will track it.
Hi Shekn,
Any news about 2.2.1 GPU support ?
Phil
Post by Shekn » 25 Oct 2024, 14:55
No
Post by opoppopopp » 30 Oct 2024, 21:00
Global settings for AO is gone, right?(I remember there is AO settings in render settings tab) So how to change ao setting for that "Cycles AO" channel?
Right now I just do a separate AO pass...
Post by Shekn » 31 Oct 2024, 13:33
There are two methods to render AO pass. First - render Cycles AO channel into separate image. If activate Fast GI Approximation in Light Paths parameter, then AO Distance allows to tweak the AO effect.
Another way. Create a separate pass and override the material of all geometry objects. Assign emissive shader with cycAmbientOcclusion node. Render this pass into image.
