Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
During the render of the vdb the volume velocity attribute is loaded to the renderer. But I did not properly test the result. It requires the vdb-file with velocity grid.
This is a sample VDB from openvdb.org https://artifacts.aswf.io/io/aswf/openv ... -1.0.0.zipShekn wrote: 25 Jun 2024, 03:58 During the render of the vdb the volume velocity attribute is loaded to the renderer. But I did not properly test the result. It requires the vdb-file with velocity grid.
Please check below img, It has v grid, and can be rendered(change 'density' to 'v' in priciple volume shader)
But seems motion blur not working
I check the sample in the Blender. It render the motion blur of the vdb. It supports additional parameter which allows to select a specific grid as velocity grid.
By default (and also in Sycles) only the grid with the name "velocity" considered as actual velocity grid. So the grid with the name "v" is ignored. I will try to add this feature in the next update (whenever it will be).
So it means if I export the velocity vector grid with name "velocity" it will work with current Sycles? that will solve my problem already.Shekn wrote: 26 Jun 2024, 03:39 I check the sample in the Blender. It render the motion blur of the vdb. It supports additional parameter which allows to select a specific grid as velocity grid.
Can you post a correct rendered image with motion blur? either in SI or Blender(while I don't know much about it
About the name of the velocity grid - I think that it should work.
Here is a render of vdb with motion blur in Blender
Update Sycles version 2.2.0. Download it from the release page on the GitHub. This page contains more or less detailed update notes.
One thing that's important to say at the outset is that this version has some functionality degradation. OSL shaders and denoising are disabled. For some reason (and I do not understand why) the osl and denoising libraries required for rendering are not loaded into Softimage. By some reason.
Addon uses the latest version of Blender's Cycles render engine. Some time ago the developers redesigned the principled BSDF shader node. They changed the functionality and especially the shader node ports. So materials with this shader from previous versions of the addon will not work.
Light linking is my life SAVER!
You mean newer version dll e.g. Open Image Denoise lib no longer loaded with Softimage?
but lost of denoising ...Shekn wrote: 19 Jul 2024, 15:59 One thing that's important to say at the outset is that this version has some functionality degradation. OSL shaders and denoising are disabled. For some reason (and I do not understand why) the osl and denoising libraries required for rendering are not loaded into Softimage. By some reason.
Yes. Blender use modern version of the OIDN, which support different devices. It can use not only cpu for denoising, but also gpu and some other virtual (as I understand) devices. That's why it won't load properly in Softimage. This problem can be solved, but further research is needed.
Thanks Shekn
in the meantime we can use your FX Denoise denoising node
Hi Shekn,
Just installed the last Sycles_2_2_0.xsiaddon but it didn't see my gfx cards at all only my CPU
I get back to Sycles_2_1_3.xsiaddon --> Ok
All the best
Phil
All the best
Phil
For detect gpus the renderer use precompiled binaries, which placed inside the folder Sycles\Application\Plugins\lib\ This folder contains many different *.zst files for different gpu models. You can try to download Blender 4.3 and copy these files from the distributive to the folder of the addon. May be it will help.
Hi Shekn
It doesn't work at all
Yes, I also checked it. On my PC, which I use for developing, all gpus are visible. On another pc - not. I don't know why it happens. It has to find out.
Ok thanksShekn wrote: 23 Jul 2024, 07:58 Yes, I also checked it. On my PC, which I use for developing, all gpus are visible. On another pc - not. I don't know why it happens. It has to find out.
I have yet to try this version, but can't wait !
- motion blur on particles and volumes
yaay!
- Output preview render result in hdr-mode
HDR Viewport region Yaay!
- Include noisy beauty pass into multilayer exr. Denoising should be activated,
and also Include Denoising Passes should be turn on
Yaay !! BUT isn't denoising not working?
And on the same note, that to me is a pretty huge and unfortunate regression
for both almost instant region previews, and final render acceleration
As wireframex mentioned, your FX Tree implementation of the denoiser still works great, and is super useful for denoising other AOV's other than the beauty.
https://ssoftadd.github.io/fxDenoisePage.html
But really not as convenient while working, and again, no denoising in the region involves waiting MINUTES instead of literally under 5 seconds for descent representation of what's going-on.
So I really hope this could be resolved eventually.
In any event, thanks so much for all these great enhancements !
Cheers,
-J
yaay!
Cheers,
-J
im rendering a vdb static image, when i use the CPU only it renders the frame in 13 seconds, when i switch to GPU (i have 2x 1080) it takes more than 1 minute (at 64 sampling which is low)
something is definately wrong, not sure whats going on
after couple tries once now i open softimage it doesnt recognize the graphic cards anymore, just cpu
