Pen mode on a Wacom makes me want to eat glass. The sharp stuff....
There's multiple apps out there based on Qt, and working with them is really, really annoying until you switch to pen mode.
And then working in it gets really really annoying too
Hi, I'll try with my frenchenglish...noseman wrote:Would you be kind enough to create a short presentation of your Partition workflow?NNois wrote:@noseman I must say you have to try at least once in your life the pass/partition/override Softimage system in your life.
And then, you'll say "what the fuck !" ( like every max/maya and as i see C4D users generally says when they saw )
Apparently I haven't understood the importance and power of it. I apologise for that.
The spirit is close to this but, you know when you are working with complexes scenes with dozens of objects operators and materials. A plugin like this begins to be not as that an helper than that, but more and more a Stopper because you don't have any cue (and visual cue) about what's changed in your scene, so... you start to mess things.noseman wrote:Before I attempt to show anything related to NNois' post, please take a look at a plugin Called Render Elements and see if it covers some or all of your requests
I'm posting from my tablet and I'll be in the office shortly
BTW I'm in Toronto Canada so I guess GMT+5 (eastern time like New York)
http://vimeo.com/18601732
Yes, switching Passes is like you have opened a new scene.noseman wrote:Yes, I see your point NNois.
In what way is that visible in Softimage?
How do you know what is what? Do you select the current partition and the whole scene changes?
Is there a video that shows that somewhere?
It's a great experience chatting with you guys. I appreciate it hugely. My eyes and ears are wide open.
one minor issue is that I'm on Mac…Hirazi Blue wrote:@noseman - You could take the ancient Mod Tool for spin, all the fundamentals are there...
A: The C4D Extrude tool with the Caps option enabled is essentially a thickness tool.Q: is there a dedicated 'thickness' tool? The 'explode' tool you use in the second video looks a bit like a workaround.
Humm... how?3DKiwi wrote:A: The C4D Extrude tool with the Caps option enabled is essentially a thickness tool.Q: is there a dedicated 'thickness' tool? The 'explode' tool you use in the second video looks a bit like a workaround.
There are reference planes, yes. They can be aligned to anything, also verts/edges/polys. Grid snapping will work on the ref plane.3DKiwi wrote: Does Softimage have a modelling guide / construction line system? C4D has an excellent guide and dynamic guide system that's great for technical modelling. Something not obvious in the product pages on Maxon's site. The following page from C4D Cafe's R14 review (written by me) gives an overview of the guide system.
http://www.cafedownloads.com/reviews/r14/snapping.html
I get it. In Soft, there's an 'extrude along normals' operator, that would be comparable.noseman wrote:3DKiwi is talking about our polygon extrude tool.
Well, non-destructive would be better... ; )noseman wrote: It's not a "live" tool or deformer and can only be applied to a "frozen" (editable) polygon object.
Having said that, it's exactly like a thickness tool, if "destructive" polygon modelling is what you're after.
Well, I think you can guess the answer... ; )noseman wrote:question:
are the attributes of the modelling Stack animatable?
Can you change the thickness of a shell, for example? Is there a limit what you can animate?
I'm investigating alternative solutions and this question popped up.
Hi, if you see the videos from noseman, every parameter he changes has a small circle at the left of the parameter name. When you ctrl+click those circles you add keyframes to the parameters (like the round-cornered squares from softimage, except you need to press ctrl when you click them)Eugen wrote:Well, I think you can guess the answer... ; )noseman wrote:question:
Everything is animatable, with a few rare exceptions.
See the greet dot ('divot') to the left of any param? That's where you can set a key by clicking, or get a RMB menu with shortcuts to the animation editor, expression editor, etc.
If you activated 'auto key', and change a parameter, keys are set as well, of course.
There's a color code to the divots. Red curve icon: key at this time, green curve: somewhere inbetween keys, yellow curve: param was changed, but no key has been set.
There's these small arrows in the top left corner of a 'property page' (the parameter window). You can go to the next or previous key there.
It's perfectly intuitive and simple...
And all that is just a small part of what people are talking about when the great UI of Softimage is mentioned.
