SiScatter
SiScatter 2.0Author: Julien Carmagnac
A scattering plugin from Julien Carmagnac, author of »Instance On Curve«. SiScatter offers a high level of control over the scatter placement:
This scatter tool distributes particles based on the »emTool _ Equal Distribution on Surface« Compound from Eric Mootz (thank you Eric !). I tweak this compound to work together with »Delete Particles Near to Boundaries Edges«, »remove closest geometry« and »remove inside filter« compounds.
This tool build an ICE Tree and create a custom property under the point cloud object to tweak all ICE parameters. So you can edit entirely your scattering without open your ICE Tree. List of available modifiers: color by gradient color by shape id color by texture map filter by boundary edge filter by closest geo filter by fractal filter by random
Continue reading in the si-community thread. Video demo here.
local backup: siScatter.xsiaddon
yashugan
Re: SiScatter
Post by yashugan » 17 Aug 2016, 07:05
I'm sorry but there is no way. No one have be able to make it work? ~o) Thank you!!!!!
Pooby
Re: SiScatter
Post by Pooby » 17 Aug 2016, 07:56
You don't write the name of the image file. You just access the texture map that contains the image.
yashugan
Re: SiScatter
Post by yashugan » 17 Aug 2016, 08:30
Can you please do a example? I tryed this too, but i didn't workkk :( thank!
julca
Re: SiScatter
Post by julca » 17 Aug 2016, 10:12
Hello @yashugan !
Thank you for your comment !
About texture map, I notice that you just need to recreate the "Get Data" node inside the "siScatter _ Filter by Texture Map" compound : cf. screenshot
I don't understand why for now, I need to investigate more..
julca
Re: SiScatter
Post by julca » 17 Aug 2016, 10:22
A way more simple solution :
Just disconnect the "siScatter _ Emitter" node, and that will be ok (it may make a double reference that create a sort of path error).
yashugan
Re: SiScatter
Post by yashugan » 17 Aug 2016, 12:05
I'm sorry but i don't work:(
There are possibility to fix your interface with a more direct "texture " picker to filter the objects? Thank! :)
julca
Re: SiScatter
Post by julca » 17 Aug 2016, 13:31
yashugan wrote:I'm sorry but i don't work:(
Yes, I will update the addon, but in the meantime it may work !
cf. gif animation for the full explanation step by step (sorry for the gif size/compression..)
Let me know if you still have problem.
yashugan
Re: SiScatter
Post by yashugan » 17 Aug 2016, 14:20
ho yeah!!!!!!!!!!!!!!!!!!!!!!!! thank you!!!!!!!!!!!!!!!
this will help my work 1000 times!!!!!!!!!!!
Fantastic! and thank again for the patience with me!! :D
julca
Re: SiScatter
Post by julca » 20 Aug 2016, 09:20
Hello !
I've just upload a new version of siScatter (1.6) with :
  • - New alignment options based on emitter's border edge :
    • Cutoff distance
      Orientation offset with variance
    - A new option in "Filter C" tab :
    • an accurate Neighbors delete with distance option
    - Bug correction on Texture Map
Gif Quick Demo A
Gif Quick Demo B
druitre
Re: SiScatter
Post by druitre » 20 Aug 2016, 11:42
Thanks Julca, this has been one of my favourite collections of nodes!
jonmoore
Re: SiScatter
Post by jonmoore » 20 Aug 2016, 12:53
Thanks Julca. Such a great scattering toolset.
yashugan
Re: SiScatter
Post by yashugan » 20 Aug 2016, 14:47
Fantastic! i'm really happy! i'm doing landscapes just in those days, and your scatter is simply awesome! thank!!!!!!!!!!
julca
Re: SiScatter
Post by julca » 20 Aug 2016, 15:45
Thank you all for your comments !
I'm glad that you find this tool useful.
yashugan
Re: SiScatter
Post by yashugan » 20 Aug 2016, 16:02
Apologize me, but i can't find any more the other Randomize, have you removed them? :ymblushing:
julca
Re: SiScatter
Post by julca » 20 Aug 2016, 16:41
yashugan wrote:Apologize me, but i can't find any more the other Randomize, have you removed them? :ymblushing:
No problem, that's probably because you need to rebuild a new version of siScatter from scratch.
Let me know.
yashugan
Re: SiScatter
Post by yashugan » 20 Aug 2016, 19:30
Ops, it seem that's are missing, apologize me, i maded a bad analize of the result.
Or probably i'm doing somthing wrong again...
any way i can try to manage:)
thank again! by
