Announcing Redshift - Biased GPU Renderer
Redshift Renderer 2.5 Version 2.5.32 updated Oct 3rd 2017 / Redshift continues to support the Softimage
plugin, posting updates almost weekly. Version 2 added many new features including volumetrics (OpenVDB), nested dielectrics, a new
BRDFS response, new SSS models, light baking and a new PBR based redshift material.
From the company's website: Redshift is a powerful GPU-accelerated renderer, built to meet the specific demands of contemporary high-end production rendering. Tailored to support creative individuals and studios of every size, Redshift offers a suite of powerful features and integrates with industry standard CG applications. Biased Rendering: Redshift has the features and uncompromising quality of a CPU renderer, but at GPU rendering speeds. Unlike other GPU renderers out there, Redshift is a biased renderer that allows the user to adjust the quality of individual techniques in order to get the best performance/quality balance for their production. Out-of-Core Architecture: Redshift's efficient memory management allows rendering of scenes containing hundreds of millions of polygons and TBs of texture data. Proxies and Instances: The user can export groups of objects and lights to Redshift Proxy files which can be easily referenced by other scenes. Proxies allow for powerful shader, matte and visibility flag overrides as often required in production. [..] Follow the product link to continue reading.
Pricing information: Price is $500 for a node-locked or $600 for a floating license (5 lic. minimum for floating). Both options include 1 year of maintenance. For other options, see the purchase page.
author link: http://www.redshift3d.com / product page / download: ../viewforum/36/ / si-community announcement- and render tests thread
Cacoman
Re: Announcing Redshift - Biased GPU Renderer
Well, the advantages of the Titan over the GTX 780 are the following
200 More CUDAS
6 gigs against 3 gigs RAM
But the memory bandwith is the same 288.4 GB/sec
So the Titan will render a little bit faster than the 780, and is able to allocate more memory for textures, rays, etc. But frankly, before the Titan I had a GTX470 with 2 gigs in RAM and never got in trouble.
The reports from a guy having both the Titan and the 780 is that the speed is the same, due to the same memory bandwith.
I went to the nvidia site to check on this, and I just found the GTX 690. I haven't seen that before. I guess is new. But from what I just read from the specs sheet, seems to me that actually this one is the winner.
3072 CUDAS vs 2688 of the Titan
Both 6 Gigs
and the memory bandwith is higher than the Titan.
384 gigs/sec vs 288.4 of the Titan.
Damned!!! This was not around when I bought the Titan....
200 More CUDAS
Both 6 Gigs
To create something that does not exist, to exist.
Falam
The 690 came before the Titan, it is more similar to a dual card setup. As for regular, model, texturing, ICE operations, a 5xx,6xx,7xx series cards are more then adequate. If you want the extra RAM, you could spend the $1K (US) on a Titan, I don't really think it is worth it unless you are doing major GPU rendering, as with RedShift as you do.
scaron
@cacoman, @draise... thanks for the feedback, i will just need to try it myself.
my questions are because of how arnold and vray are integrated into softimage, its not their fault sometimes it is softimage's fault because their sdk doesn't provide the necessary granularity to match the mental ray integration. the scenarios i outline are difficult areas of the sdk in regards to rendering plugins, i wanted to see if redshift has the same issues or if they have workaround these issues
s
s
If I understand you correctly, no it does not have the same issues. I'll check further to see if this is the case. Integration is much like MR (better in many ways) and if you modify something on a big scene it does not seem to have to re-transfer the entire scene.
1) No, it does not seem to. I'll check further. It exports very fast with minor changes so I think not.scaron wrote:-if you have a large scene with many objects and you do a modeling change on one object, does the entire scene need to be reprocessed/exported?
-is instancing supported? through ICE?
-what happens when you do modeling changes to an object which is instanced?
-is there a fly through mode? ie. do you have to re export the scene every time the frame changes even if it is static?
-what happens if you import an softimage model from disk? does the entire scene need to be reprocessed/exported?
2) Yes, instancing is well supported. For ICE, I think so, will check.
3) Yes there is a flythrough mode. Even without flythrough, only changes to the scene are exported. It's very fast. (less than a second or two in most cases).
4) I don't think so. Will check.
Only partially helpful but I'll look into it further.
Kzin
without writing to much, the best thing about redshift compared to mr, all is working like it is intended. and you dont have to care about render features which the renderer can, but no one implemented it. you get whats on the renderers list because the renderer is under support which makes bugfixing alot faster.
I've had a chance to double check on some of this:
2) Instances and ICE instancing are well supported.
3) Changes to instances seem to happen immediately.
4) There is a flythrough mode for lighting purposes but if the scene has animated parts only those parts are updated between frames which is very fast.
5) As with everything else, RS seems smart enough to know what has changed and what hasn't.
Hope that helps
1) No. RS is smart enough to know what has changed and what hasn't.scaron wrote:-if you have a large scene with many objects and you do a modeling change on one object, does the entire scene need to be reprocessed/exported?
Hope that helps
scaron
yes, this does! thanks...ActionArt wrote:I've had a chance to double check on some of this:
Hope that helps
El Burritoh
Sorry I'm late here... I've just been so busy using Redshift on any project I possibly can... ;-)
Steve, I'm surprised you're not testing this yourself. I think your input would be valuable. But I know there's the relationship with Solid Angle.
For being an Alpha product, with a long roadmap yet ahead, I'm downright impressed with the variety of projects I'm able to render with Redshift already. And the beauty of it is it's seamless integration with Softimage. From my experience, it scales quite nicely. That said, I've never done anything like those crazy Whiskey Tree shots with trillions of polygons, and although RS suits our purposes at the commercial/broadcast/cinematic level, I'm simply not in a position to comment on it in terms of big money shots like the wide vistas of Elysium. I've just not had to render anything of that magnitude yet, so I can't say for sure. That's why I wish someone from studios like Whiskey Tree could join the alpha. Users in your position would have some valuable insight into Redshift's use at the heavier end of the scale.
Redshift is not even in beta yet. Considering how young it is, it's remarkably mature. Nic, Panos, and Rob have something to truly be proud of. I can't wait to see where it goes, and we continue to use it on any production we can (so far my last 5-6 jobs have all been in RS).
adrencg
I just finished a medical animation job with Redshift (2 minutes) and it was the rendering portion was the easiest time I've ever had -- in terms of scene setup and especially render times. At 720p, the average time per frame was 8 minutes. That average is kind of skewed because there was one trouble scene that was 30 minutes per frame, but most of the shots were around 3 minutes per frame. That scene now renders pretty well because they released a fix that solved some issues. They're great about listening to the users.
McNistor
Any support for OpenCL coming in the future?
Radeon cards are cheaper and stronger than nvidia's which I ditched a while ago.
-Thucydides
-Thucydides
BenR
Well here's the "coming soon" page: https://www.redshift3d.com/products/coming-soonMcNistor wrote:Any support for OpenCL coming in the future?
No idea about timeline.
benoit81
interview of Redshift, Nicolas Burtnyk (CEO) :
http://www.3d-test.com/contenu.php?id=2747
mkr
So open beta coming soon... nice.
owei
..and you may already be able to apply to the beta here:
https://www.redshift3d.com/get-redshift
cheers,
oli
cheers,
oli
http://www.pixelpanic.de
BenR
Thanks for the link!benoit81 wrote:interview of Redshift, Nicolas Burtnyk (CEO) :
Interesting interview. One message though is that OpenCL is on the "long-term roadmap" and they haven't done much work on it yet. Perhaps it should not be on Redshift's "coming soon" page.
As others have said, I have really enjoyed testing Redshift and am really impressed by the work they are doing on integration.
