Post by wireframex » 26 Aug 2021, 16:13
Great :)
gaboraa
Post by gaboraa » 27 Aug 2021, 15:53
Just awesome
Post by Shekn » 28 Aug 2021, 08:12
Very small update with the fix of the very stupid bug in material previews: https://github.com/ssoftadd/SSoftAdd.gi ... 1.xsiaddon
Post by wireframex » 28 Aug 2021, 09:14
Thanks man ;)
Surface_VR
Post by Surface_VR » 31 Aug 2021, 08:08
Excellent!
And thanks for fixing the problem with GES import/export not installing on Blender 2.9x, as mentioned on GitHub!
SPJ
Post by SPJ » 02 Sep 2021, 12:03
Thanks! :ymparty: Will give this a try soon.
Post by Maximus » 06 Sep 2021, 08:41
hello, i have a problem with the latest addon, there isnt anymore the option to select GPU on any render option panel in scycles now, am i the only one?
also the cpu render usage never goes above 50% during heavy high sample renders, while before i had 100% fully utilization, something is off
Post by wireframex » 06 Sep 2021, 16:54
Maximus wrote: 06 Sep 2021, 08:41 hello, i have a problem with the latest addon, there isnt anymore the option to select GPU on any render option panel in scycles now, am i the only one?
Hey Maximus,
Just create a new scene with a null
then File/merge your scene with it --> it will works ;)
Save your scene and erase the null
Phil
Post by Shekn » 07 Sep 2021, 08:14
If you see only CPU device in Performance - Devices List, then it means that system can not find correct devices of other types. In Sycles\Application\Plugins\lib folder there are severel *.cubin files. The system use it to recognize gpus. If these files are not compatible with gpu, then it can not be founded. I dont't know why it happens and how to fix it. You may try to get these files from different versions of the Blender distributive, but the result is not predicted. With some files the system can recognize device, but the render result may differ from cpu tasks or even have artifacts.
About cpu load. In Sycels render settings in Performance tab there is a paramter "Thread Mode". When it set to "Auto-detect", then the renderer use all threads of the cpu. But if it set to "Fixed", then it's possible to set explicit number of cores, which will be used for rendering. May be you activate this option?
Post by wireframex » 07 Sep 2021, 15:37
I have the same Maximus problem and the only solution you gave before was the null tip and it works for me ;)
Post by Hirazi Blue » 08 Sep 2021, 19:18
Wanted to try the new version, but I now get a red triangle in the Plug-in Manager for all versions (1_10_1, 1_11 and 1_11_1).
So I guess Softimage finally has stopped working after the recent Windows Update... :-h
Version 1_10_1 did work in the past, but now has stopped working as well...
Update: 1_9_1 does still work... :-?
Post by Shekn » 09 Sep 2021, 05:45
Try to uninstall all vc-distributives from the system. May be this will help, because the last version of the Sycles 1.11.1 contains all necessary files in the addon package.
Post by Hirazi Blue » 09 Sep 2021, 10:21
Sadly that won't be an option as that would inevitably break other important software...
You don't have a version handy without the built-in dependencies?
Post by Shekn » 09 Sep 2021, 13:15
Of course, you can delete *.dll files from the Sycles addon directory. You need only the following files: cyclesPrimitives, cyclesRenderer, SyclesICENodes (these files contains actual addon functionality) and necessary dependencies for it: OpenColorIO, openvdb, tbb and yaml-cpp.
May be you have installed some other addon, which conflict with the Sycles? It's potentially possible.
Post by Hirazi Blue » 09 Sep 2021, 13:19
Okay, I will look into it tomorrow...
Post by Maximus » 10 Sep 2021, 19:03
so yeah i tested this engine quite a lot lately, cranked the sh*t out of it
here is a 44 mins render with insane samples and light bounce.
cpu amd 5950x and 2x 1080 nvidia
