TMNT Complete Episode Work/Image Thread
Re: TMNT Complete Episode Work/Image Thread
Cool!
Progression is indeed remarkable!
Shredder565
Shredder565
Negative opinions voiced elsewhere aside....I'M Happy with the progress at least.
If I had short projects, i'd start it and never complete it with starting something else that was short.
old
new
old
new
Shredder565
considering the last time i truly tackled this with new elements was from 2013, i think this new intro was definetly needed.
It's much clearer to see detail.. it's a little smoother. it's a bit more detailed. whether or not it will actually run better together remains to be seen, but so far, i like most of the shots as they are.
Shredder565
4 intro shots left after this one. a little break once it's finished..andthen plowing into act 2 again.
a much needed new turtle blimp after the last one tackled in 2013.
Shredder565
Back section is all that's left and i can complete shot 13.
Shredder565
Shots one through the logo are finalized.
Everything from Leonardo Leads to the end is finalized.
Everything in between, not so much.
EVERYTHING is new. Brand new buildings, shadow effects, light effects, shape animation, character models...backgrounds.
nothing was brought over from the last 4 tries. started 3 weeks ago, almost done.
Shredder565
So, h ere is one thing to fix now that all the intro elements are at least created.
Shots of the four turtles moving against clouds are REAL blurry and hard to make out movement. even when i remove blur in vegas pro rendering.
Part of the problem is that non full frame to full frame conversion, things move by too fast in 60 frames per short shot.
but taht can't be the only problem. there has to be a way to make moving shots look smoother.
Shredder565
I'm still not happy with a few shots. The Turtle Van spring shot. The Weapons drawing cloud shot. Shredder slicing picture shot needs finishing.
Everything from 'Splinter taught them' to the end is finished. Everything from the first shot to the turtle van opening is finished. it's just the in between stuff i'm never happy with.
Either due to my limitations, or the limitations of the programs i'm using that makes it look sloopier than it should be...but more than likely the former.
Shredder565
i'm curious as to anyone still following, what do you think needs improving on that intro?
I've been looking at it too long, except for the obvious, not sure how the rest of it looks to outsiders.
Shredder565
near complete.
I am not happy with shots 6. 8 and 13.
6 suffers from being too short in frame rate. trying to reproduce the video as shown on the show exactly.. it all goes by WAY too fast.
8 suffers from a motion blur problem that may be either softimage or vegas 13's fault. despite turning blur off.
it looks like it goes by too fast and you can't make out the detail clearly.
13 also has a motion blur problem, despite the blimpbeing attached to the camera itself for smoothest possible tracking. i can't seem to work out the issue to make it look smoother.
other than that, and not b eing able to STILL get the camera projection working for shot 11
I like what i have here and think that it was a much needed worthy upgrade. and the LAST upgrade. time to move on.
Shredder565
a months work finally finished
