Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
I3D
- Skype: ironic3d
Hi Shekn
I ran into a problem working with sycles and blendermada. Loaded the compounds all well and assigned them and changed their properties without an issue. I was rendering all the time of course and no crashes. I saved the scene, closed XSI. Next day trying to load the scene and hitting render will crash XSI instantly. If I remove the materials of blendermada from all the objects the scene will render fine. If I try to add a new material with a blendermada shader the scene crashes again!!! the dump shows the following error:
"The thread tried to read from or write to a virtual address for which it does not have the appropriate access."
It doesn't show the process, but might be converterop.dll
Is this an issue with blendermada that needs updating?
I3D
- Skype: ironic3d
I think I found the problem, it is with the diamond shader. Although it renders fine if I was in a session and render it, it will fail if I save the scene, load XSI again and try to render the scene again. This is the warning when I add it to a surface:
# WARNING : 3234 - Referenced Shader compound not found during import. Please make sure you have it installed. Name: "Noise" Version: 1.0.
# WARNING : 3236 - Unable to set a parameter value during shader compound import. ParamName: "Value1".
# WARNING : 3236 - Unable to set a parameter value during shader compound import. ParamName: "IOR".
# WARNING : 3000 - Can't do name resolution on a source port on shader node #2 with port named Value.
# WARNING : 3238 - Unable to resolve source when trying to make connection during shader compound import. SourceName: "Value" TargetName: "IOR".
Application.CreateShaderFromProgID("XSIRTCOMPOUND.Diamond.1.0", "Sources.Materials.DefaultLib.Material17", "Diamond")
Not sure if there are other shaders that cause the same issue.
I3D
- Skype: ironic3d
Another theoretical question, would it be possible to export the scene to a native Cycles format (like Arnold's Ass file) to be able to render the scene using any of the cloud render options available for Blender?
I3D
- Skype: ironic3d
And where is your Patreon page mate?
1. Blendermada materials were exported from Blender for old version of the Cycles render. Now parameters of some shader nodes are changed and reorganized. May this is a reason of crashes. So, does not use these old materials. In any case, I will try to understand, may be it is possible to check something in rendering process and block actions, which can produce crashes.
2. There are no format for storing Cycles scenes. As I remember, creating something similar are in developer plans, but when it will be released - it is unknown.
I3D
- Skype: ironic3d
Thanks Shekn
It seems the blendermada is missing a noise component, might be the issue!?
Surface_VR
Update.
Support for default image shader nodes is great!
Key Shekn,
Do you know if it will be possible in close future to support legacy particle or other things like emfluid or SPH type ?
It is already support emfluid rendering right ?wireframex wrote: 11 Apr 2021, 13:58 Key Shekn,
What you mean by "legacy particles" and SPH? emFluids is supported by using ICE. There is tutorial in the manula how to render emFluids simulation.
- Legacy particles was the particle system before ICE and still working with SI2015, sometimes it is easier/faster to use than ICE
(http://softimage.wiki.softimage.com/ind ... es_Toolbar)
- SPH (is an ICE fluid solver) is finally working after a SI restart - dont know why it didn't work
Oups sorry you're rightShekn wrote: 11 Apr 2021, 15:08 emFluids is supported by using ICE. There is tutorial in the manula how to render emFluids simulation.
Now it seems that there are no reasons to add support of legacy particles. This will add complexity to the code and increase the number of potential bugs. But may be implementation will not be so complex, and then it will be possible. So, I need more investigations about it.
Haimund
Hi
Thank you for this awesome plugin. I really appreciate.
I have a question, can this take particle scale attribute? It works for particle's size but seems don't work for scale?
Thank you
Thank you
Ok, I will try to add support of the scale attribute at the next update. I hope, that this will be possible.
looks like Cycles-X is coming
