help with last similar operation in stack
kowy
Re: help with last similar operation in stack
I have question regarding axis locking
https://download.autodesk.com/global/do ... =d30e47900 section where (If Allow Double-click to Toggle Active Axes )
If it's possible to script those - locking/unlocking axis, theres a of of clicking if i'm using often (ex: x y z to lock axis & smt else to unlock) ~ blender approach
ps: script editor doesn't show record actions - there are somewhere hidden ...
Kolya
Hello, I've made a plugin for that.
Commands SetTransformAxisX(), SetTransformAxisY(), SetTransformAxisZ() make only one specific axis active or all active,
ToggleTransformAxisX(), ToggleTransformAxisY(), ToggleTransformAxisZ() enable/disable specific axis
https://drive.google.com/file/d/12JNAMb ... sp=sharing
kowy
thanks !
i've modified so it will work like blender - where holding a button will enable only one active axis - u'r plugin have to type 2 axis to enable & 2 to disable
amazingly how u can modify xsi ))) thanks again
function XSILoadPlugin( in_reg ){
in_reg.Author = "Kolya";
in_reg.Name = "ToggleTransformAxis";
in_reg.Major = 1;
in_reg.Minor = 0;
in_reg.RegisterCommand("ToggleTransformAxisX");
in_reg.RegisterCommand("ToggleTransformAxisY");
in_reg.RegisterCommand("ToggleTransformAxisZ");
in_reg.RegisterCommand("SetTransformAxisX");
in_reg.RegisterCommand("SetTransformAxisY");
in_reg.RegisterCommand("SetTransformAxisZ");
//RegistrationInsertionPoint - do not remove this line
function ToggleAxis(axis){
var ActiveAxis = GetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED");
var x = 1 + axis;
var y = 2 + axis;
var z = 4 + axis;
if(ActiveAxis == y || ActiveAxis == z || ActiveAxis == y+z || ActiveAxis == 0)
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", ActiveAxis+x);
else
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", ActiveAxis-x);
function ToggleTransformAxisX_Execute(){
if(GetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED") !== 1)
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", 1);
else
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", 7);
function ToggleTransformAxisY_Execute(){
if(GetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED") !== 2)
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", 2);
else
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", 7);;
function ToggleTransformAxisZ_Execute(){
if(GetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED") !== 4)
SetUserPref("3D_TRANSFO_EDITED_AXIS_CHANGED", 4);
else
kowy
another problem that i'd like to solve is flattening according to axis with changed pivot position
example:
by default to change global + cog will be
Scale(null, 1, 0.000000000001, 1, siRelative, siGlobalCOG, siObj, siXYZ, null, null, null, null, null, null, null, 0, null);
but when i'm changing to a modified pivot (alt dragging) will have something like this
Scale(null, 1, 0.000000000001, 1, siRelative, siGlobalCOG, siObj, siXYZ, null, null, null, true, -1.8472517205702, -5.51816828300463, -0.436557306254863, 0, null);
is any way to define where's my current pivot position ?
example:
Kolya
Sorry, I don't know a way to get current pivot position.
kowy
found only this, dont know how to manipulate with them
0x08 Center Pivot mode. If there is no center pivot, this is the same as Object Parent mode (0x06).
http://docs.autodesk.com/SI/2015/ENU/So ... ents-2.htm
Kolya
That's for changing transformation referential mode (buttons on the transform panel Global, Local, View etc.)
SetTransformRefMode(8);-
kowy
I wonder if there's such a future like blender's Spin
select some edges, place a pivot & extract towards that direction(with desired loop), a good example will be pipes
I had a lot of troubles doing romb shape in 4 directions (4 corners & from each selected edge) good example
Kolya
Hello, you can achieve something similar by changing object's center and then applying Extrude Op.
If you wont, I can try to make a plugin to optimize the process a little.
kowy
Hello, was thinking a way to improve it -> too many clicking for one extrusion
1. move center
2. rotate
3. extude along normals: frame object, subd's, length, transform per subd, rotate axis (this can be scripted)
main problem is center move & rotation - after an extrusion there's no way to change center for position/rotation (history tab won't allow that, instead will move center after last operation ) - so i have todo it again
my idea is a temporary pivot/null
* dragging will change length
* rotation will change the orientation
* scale - subd's numbers
as for pivot I'm looking towards texture projection(create new texture projection - is a template that will autodetect orientation, not the best, better then nothing) - so after freeze will delete all null's/pivots
as for ice, idk if it can be done there
thanks !
1. move center
2. rotate
thanks !
kowy
For u'r addon FFill, love it !
I'd like two additions to it
1. it works only for one object at a time, if it can be done for multiple selection
2. fill until there are no caps to fill - good example will be a cylinder with n vertical/U subd's, delete caps, fill holes
Kolya
Hello, I made a quick prototype with ICE. I'll try to finish it when I have free time
Kolya
Finished it. The plugin creates two nulls that control the center of spin, angle and number of subdivisions.
https://drive.google.com/file/d/11uxNEI ... sp=sharing
kowy
great work !!!
keeps history, intuitive & easy to use. Will test more !
Колян, спасибо за плуг;)
Kolya, great plugin;)
gaboraa
Wow, another great tool for modeling!
