im in need of using this plugin for a project and having an hard time rendering out the images as vector displacement maps.
there is a node aaOceanDataShader which has a file output "write shader data" option, but nothing gets saved to disk.
Last time i used aaOcean was the first iteration which had a very different workflow, anyone would be able to help?
aaOcean open sourced...
aaOcean Suite The Open Source aaOcean Suite is a collection of Softimage ICE nodes and mental ray
shaders that implement Jerry Tessendorf's paper on simulating ocean waves, which is
currently the most widely used method for open water ocean surface modeling in the
industry.
This particular implementation presents itself as a 3D deforming grid inside Softimage, which then becomes the source of vector displacement map sequences that are sent to Mental Ray for final rendering. One of the benefits of using this approach is that it opens up the possibility of making other 3D objects inside Softimage react with the ocean grid via ICE. Another benefit is the speed that it brings in setting up your ocean right inside Softimage on a low resolution ocean grid to set basic parameters like wave height and speed, rather than rendering a sequence of images in Mental Ray. Works nicely in conjunction with Werner Ziemerink's Wave Curl.
local backup: aaocean.zip
author site: http://www.amaanakram.com / download: /?page_id=131 / si-community thread / repository @bitbucket.com (archive)
Surface_VR
Re: aaOcean open sourced...
In my case, I had to do a region-rendering to get the output.
A file was created each time the frame was advanced while region-rendering
Also, it's better to add textures to Shadows and Photons so that the render doesn't look weird.
can you please share that scene? for some reasons i can not have any data written to disk.
Surface_VR
I don't know if it's helpful or not.
yeah thanks a lot, but it doesnt work, idk whats going on. It doesnt write the output on disk.
Surface_VR
1) Open the downloaded file.
2) Specify the folder to save aaOceanDataShader's exr.
3) Region-rendering in the mental ray
If this doesn't work, I don't know what's causing it.
It may be that the installation is incorrect and the shader is giving an error.
mattmos
Maybe double check write permissions in the output folder?
when i drag a render region this warning pops up
"' WARNING : PHEN 0.5 25 MB warn : [aaOcean Shader] Shader's Transform input is zero. Using Identity instead
' WARNING : PHEN 0.5 26 MB warn : [aaOcean Shader] Foam Min/Max mismatch. Please set the Foam Min/Max values in foam shader to Min: 0.429399, Max: 1.733000
but idk if that is the issue, the permission in the output folder is fine since its writing the normal render files i think there is some issue with the installation of the plugin.. idk.
Surface_VR
Hmmm... Honestly, aaOcean has changed so much that I don't even know what it is.
There seems to be a script that can export Vector map in Blender
It might be better to do an obj export of the sea, export the map in Blender and texture it in Softimage to save time.
what softimage version you using and what aaocean version?Surface_VR wrote: 21 May 2020, 04:18 Hmmm... Honestly, aaOcean has changed so much that I don't even know what it is.
Surface_VR
aaOcean is either so-called last version "aaOceanRev345_latest" or "aaOceanRev255_stable"
aaOceanIceDeformer Major Version = 2 Minor Version = 6
aaOceanDataShader Major Version = 1 Minor Version = 0
If you search for aaOcean on the web, aaOcean_suite will appear, but you have never operated aaOcean_suite
Softimage = 2015 R2
Softimage = 2015 R2
