Vray for Softimage official release
V-Ray 3.0 for SoftimageAuthor: Chaos Group
Chaosgroup recently released the Softimage plugin for VRay 3.0.
Built on V-Ray's core platform of rendering speed, stability, and quality, V-Ray® for Autodesk® Softimage® is an advanced rendering solution for the VFX and animation industries. VRay for Softimage includes ICE support, efficient Global Illumination, versatile shaders, and much more.
What's New in V-Ray 3.0 for Softimage? New progressive production renderer for interactive and production rendering New VRaySkinMtl with layered reflections and artist friendly controls Render Mask to specify render regions using an object selection or image mask Deep Image support including OpenEXR 2.0 output emFluid 5 is integrated with V-Ray for SI.
For a full list of improvements, see V-Ray-3.0-for-Softimage.pdf (archive)
Price per license is 750€ / $1040 / 650£ or 74€ / $103 / 64£ for an educational license. It is a free upgrade for all current V-Ray for Softimage users.
Link to the vray online documentation (archive). For a previous version, the thread V-Ray for Softimage: Tutorials and Walkthrough was created on si-community.com as a means to gather community knowledge, starting with an indoor lighting video tutorial created by Oliver Weingarten.
gustavoeb
Skype: gustavoboehs
Re: Vray for Softimage official release
Post by gustavoeb » 25 Feb 2012, 14:41
nourvfx wrote:hello my frinds.vray is very faster than mr and arnold.i test it .i render 300000hair with GI in vray and render time just 1min50sec
but in arnols render time is 3min10sec with aasumples=3 and defulit sumples is=3 adn very bad quality.
after this .i chang AAsumples from 3 to 10 and render time in arnold is 27min.and even with this quality in arnold my vray result in 1m50sec very beter than arnold.arnold have nouise point and you must have uper aa sumples. vray is faster render than 3delight and mr and arnold and max well.i tested all of this render.
You are being very simplistic in the way you compare your renderers. (And you should also post some images to back it up)
Arnold uses FIXED sampling and Vray uses Adaptive sampling (as default).
Arnold ALWAYS BruteForces GI which garantees your renders wont flick. Plus it has a bunch of hair optimizations you can use to reduce render times without loosing quality.
Also it is very difficult to compare renderers unless you are using exactly the same setup (geometry, shading models, light intensity, etc, etc, etc...). Like so: viewtopic.php?p=13737#p13737
Have in mind that even this kind of comparison will not reflect real production results, since textures make a big difference in Adaptive Samplers (because of the increased contrast, making them slow), and little difference in Fixed Samplers...
Gustavo Eggert Boehs
Post by Hirazi Blue » 25 Feb 2012, 15:36
I think it's best if we're all willing to accept that nourvfx offers an opinion on using VRay from his own perspective here, not a full-fledged, exhaustive, 100% accurate benchmark comparison of all the renderers at hand...
Memag
Post by Memag » 25 Feb 2012, 15:38
We can also conclude that he likes hairy stuff. :)
curly
Post by curly » 25 Feb 2012, 18:03
A couple of questions.
How fast is Vray in scanline mode?
Can you do the Vray gizmo stuff to limit raytracing to only what you need? (see url)
http://www.spot3d.com/vray/help/150SP1/tutorials_anim.htm
Does it support long hair -> Kristinka hair -> ?
How fast is it with particles?
Those for are for me the important question determining whether I could use vray for rendering animation.
I do like te Ptex stuff you guys implementing in Vray. 3D Coat has Ptex.
Kzin
Post by Kzin » 25 Feb 2012, 19:08
vray has no scanline mode, its raytracing only.
for the gi animation thing, break your scene in passes and render the elements seperatly. should be easy with xsi's passes and partitions system.
nourvfx
Post by nourvfx » 25 Feb 2012, 20:11
hy
i test with my labtop HP4520.core i5 and 3 gib ram and atigraphic with2263mb garaphic ram
this is Enough for this test.yes???
300000hair with GI
this test with arnold with aasamples 3 and defultsamles is 3
rendertime is 3min10sec
Memag
Post by Memag » 25 Feb 2012, 20:16
What version of Arnold are you using?
nourvfx
Post by nourvfx » 25 Feb 2012, 20:20
and this is rendered with vray with DMC samples min1 max4 and GI is on in primarymode is iraadiancemap in high mode and secoundary mode is lightcash with 500sabdivs
render time:1min50sec wihch is faster and beter quality?????????tiy say maybe i have mistak is my render setup or my arnold is bad plugin if you have beter info please share with me thanks my frinds
Post by origin » 25 Feb 2012, 20:25
You need to type slower
nourvfx
Post by nourvfx » 25 Feb 2012, 20:27
hy mr Memag.i have sitoa arnold version 1.1 but when my xsi is loded in xsi masege under sofware say sitoa 3.3.6 is detected
i dont know.
i try have download last version of arnold.i cantact to solid angle but i dont have any answer.if you have arnold trial do you can send to me or share with me .pleasemy email is nourvfx@yahoo.com i dont know what i do.
Memag
Post by Memag » 25 Feb 2012, 20:31
If there is any meaning to this, I like Arnold render more.
More detail, better depth and nicer hair shadows.
Yeah, Solid Angle might help you out with the fresh version, of course.
Good luck with that Esmail.
Kzin
Post by Kzin » 25 Feb 2012, 20:32
sorry, but the quality of the arnold rendering is way better. the lighting and shading details of the hair in the arnold rendering is not comparable with vrays one (you have simply none in the vray rendering).
it reminds me a bit on the mr and 3delight comparisions. the problem was that 3delight renders hairnormals in a different way then mr. looks like vray does something similar out of the box, means more worst hairnormals? you can workaround with such problems with things like ao passes or, in mr, with shadow map lightrigs.
so if you make a comparision, be sure the quality matches. then you can compare the rendertime. ;)
nourvfx
Post by nourvfx » 25 Feb 2012, 20:56
vray quality is very bettee than arnold .do you can Denial of quality vray on the this two pic witch i loded.
in all of mode GI on vray bruteforce only iradeancemap only and light cash only vray beter than arnold i increase aa samples in arnold from 3 to 10 and my render time in arnold change from 3min to 27min.i think this beter for me i work with vray for hair render
this test .arnold with aasamples is 10 and defult samples
render tim is about 27min
Memag
Post by Memag » 25 Feb 2012, 20:59
I'm sure there are ways to optimize Arnold render.
Just read the manual.
Post by Hirazi Blue » 25 Feb 2012, 21:06
I already tried to hint subtly that it wasn't a good idea
to make this into a render comparison thread... Please don't!!!
nourvfx
Post by nourvfx » 25 Feb 2012, 21:08
i love arnold to.idont say arnold is bad we have many big project in cinema with arnold like 2012movie alice in wonderful land and many other project.
but i jast test arnold and vray.in lighing we must have separate prameters for control the quality .arnold lighing quality and render quality with to ghader.in vray brutforce i just chang samples from 8 to 32 and we have nice qualty even in interior lighing.arnold in interior lighthing is very very bad result i testing the arnold to show to yours.
