Hmmm...this file is not present. I assume it's supposed to be.try going here **Addons\3DelightForSoftimage\Application\bin\nt-x86-64 and execute licserver.exe
3delight for Softimage 3.0 beta
Re: 3delight for Softimage 3.0 beta
That I know, you should be able to install free version, just by installing the addon (let's say, drag and drop to XSI window), that's all. It's mentioned into 'readme.txt', that running the license server isn't necessary for free, 2 core version.ActionArt wrote:Hmmm...this file is not present. I assume it's supposed to be.try going here **Addons\3DelightForSoftimage\Application\bin\nt-x86-64 and execute licserver.exe
Now hear-say story, but anyway - usual problems become from anti-virus software, software firewalls, so on.
Version 3.0.4 beta was available.
From the changelog:
edit: It seems they have rolled-back the 3.0.4. version as it has been replaced again with 3.0.3.
What this means / why this happened is beyond me...
I assume 3.04 will inevitably return in a couple of days...
(but meanwhile I am stuck with a 3.04 download that I'm unsure what to do with)
Still later edit: the mystery surrounding 3.04 seems to have been solved
From the changelog:
I can't find any mention of support of the so-called "co-shaders" Aghiles mentioned (as a feature of 3.04) in their own Support Forum yet. But this could well be due to me not knowing what to look for...added map_lokup_scalar and map_lokup_color.
Quoted from here3.0.4 was broken. The display drivers were miscompiled so you basically can't render to a file.
3.04 seems to be available again... ;)
slightly extended changelog:
Shaders
mia_material* has improved reflection/refraction controls.
Bug Fixes
Density falloff in ICE particles was off. Now behaves as in MR.
Fixed crash bug in ICE volumes.
Tried 3.0.4 but get the same stupid error. I don't care that much but if I did this would be really annoying.
@ActionArt - weird...
Just found this interesting additional info on 3DfS:
The use of the so-called "co-shaders" has been (albeit sparsely) explained in this post at the 3delight for Softimage forums.
The renderer that actually does seem to work with Softimage 2012
(well, more or less),
just released a new beta 3.05...
To the download page.
Changelog:
Changelog:
3.0.5
Features
Added ability to use custom SL file location for render nodes.
Added “Shader Nodes Paths” parameter to 3delight preferences.
UVW transformations are now working.
New “Export Object” parameters in 3Delight custom preferences.
Bug fixes
sib_color_8mix in Softimage 2011
mia_material specular
incidence shader in Softimage 2011
sib_color_gradient
Rez007
Nice to see that they are still going strong with it.
3.06 Beta is available, the download page is the same as in my previous post...
Changelog:
Changelog:
3.0.6.
Features
Added support for Render Maps. For now, only main color is supported and only export format is TIFF.
New point-based algorithm delivers higher quality occlusion and global illumination.
Bug Fixes
Fixed update of custom preferences.
Shaders
Fixed texture layers, they were broken in version 3.0.5.
ShaderOp
- Skype: shaderop
Unfortunately it seems that this particular feature only works with absolute paths, rendering it next to useless (no pun intended).Added ability to use custom SL file location for render nodes.
I was trying to find a workaround using SI2011's shader definition plugins, but somehow I ended up corrupting the scene on both of my attempts. So I decided to give up for the time being.
Yet somehow I still can't bring myself to hate on 3Delight. It's still awesome.
Although I must add that 3.06 did feel a little faster than previous versions.
After 3.06 3Delight skipped a release (i.e. there was no 3.07), released 3.08 instead, which I skipped (as in: didn't/forgot to mention) and now we're at version 3.09 which brings (among other things):
Download
ChangelogNew optimizations will will have a 10-20% speed impact on overall rendering speed (only 64 bits platforms).
Download
I still get the same damn error...
Ethangar
YES! .png support!
Missed (
) a version again (3.0.10), the newest release is 3.0.11
From the changelog:
And according to Aghiles in this thread over at the 3Delight forums: "(...) the documentation is lagging behing but will be updated shortly."
From the changelog:
(Quoted from here)3.0.11 - 2011-07-20
Features
Added support for global illumination visibility flags.
3.0.10 - 2011-07-18
Features
EXR multi-channel write support. No need to install EXR libraries.
Adding finer control on how shading is performed for multi-segment motion-blur: per-frame or per-segment. Setting this option to “per-frame” can improve rendering times substantially without affecting image quality.
Motion blur property can now be specified per-object.
Clipping planes can bow be hidden
Fixes
Fixing ambiance property behaviour in some shaders.
Blinn shader lost its specular component, fixed.
Particle orientation was wrong in 2012, fixed.
Again I managed to miss some versions,
but as yesterday was "international release day" (and Vray beta announcement day), version 3.0.15 of the 3Delight for Softimage package went public.
Download from here, the changelog can be found here
This is nice! Working very well here. There's so much new stuff today I can't keep up
Thanks for all the updates Hirazi.
