I mentioned .dll corruption immed when I read the original Non working toon files. Experience....Shekn wrote: 14 May 2020, 12:39 Small update 1.9.1. Download here: https://ssoftadd.github.io/syclesPage.html
Nothing new, only some bugfixes and improvements. In particular, fix the bug with osl-shaders. Now SToon should works. For reliability it's better also to delete all *.oso files in the folder with the addon. When Cycles use the osl-shader at the first time, it compiles it to the corresponding oso-file. Some times ago Blender developers upgrade the version of the osl-compiler, and that's why all compiled shaders should be recompile. However, in principle, all should works without any such updates.
Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
sirdavid32
Web: http://www.3dcinetv.com
sirdavid32
@Shekn, 1.9.1 addon downloads as ZERO bytes file. I am trying to get it from: https://ssoftadd.github.io/syclesPage.html at the end of the feature's list. But it will only download a 0kb file.
Surface_VR
Hello Shekn, thanks for Reply.
I'm sorry, it seems that there is no such parameter from 2.8x.
Even if I used the same EXR image, the result would be different, so I was wondering if that was the cause.
As I made it brighter with Strength, the colored objects also became white, so I wanted to solve something.
In the cycEnvironmentTexture node the Color Space parameter value "Non-Color Data" is equivalent to "Linear" or "Raw" ColorSpace in Blender. "Color" in Sycles is equivalent to "sRGB" in Blender. With these equivalent settings the render output quite the similar. But in my case Sycles output slightly lighter, than Blender output. I don't know why it happens.
sirdavid32. There are some errors with links to files on the site. I will try to fix it.
Surface_VR
Thanks Shekn
I understand the difference in color space parameter values from Blender
sirdavid32
Fantastic, Shekn. Thank you for your support in all these issues.
Surface_VR
Excuse me again for HDRI talk
Special noise appears when setting a 32-bit image such as HDR or EXR
It does not disappear even if the number of samples is increased
What do you guys do when you HDRI at Sycles?
Can someone help me?
Think this is what the "clamp" parameters in "light path" try to solve, especially for artefacts in the bottom right picture.Surface_VR wrote: 24 May 2020, 11:59 Excuse me again for HDRI talk
Surface_VR
Hello opoppopopp, Thank you for information
I'll study harder!
I'll study harder!
Thanks Indeed !sirdavid32 wrote: 23 May 2020, 10:48 Fantastic, Shekn. Thank you for your support in all these issues.
im having trouble into making the HDRI appear as background, i get the lighting, i get the reflections, but it doesnt show as a background image.
in the HDRMaster addon property i've noticed that in the video demo that describe how to use it, there is under the "Parameter" tab a check on "show as background", while in the addon i have installed this feature is missing.
anyone got some solution?
To visible backround, you should turn off the parameter Transparent in the background settings. Like in the picture.
at a break of fine-tuning Cycles shader parameters...(dirty/quick fixing for a scene now...)
Still humbly voting for that quicker cache or polygon export function...
now, scene prepare is really slow for a small parameter adjustment( therefore the progressive render region not that useful )
Hi shekn
Can you add a specific path in preferences to store the HDR Master preview jpg files to avoid in the same directory HDR Files and JPG preview files
Thanks a lot
Phil
Thanks a lot
Phil
Your request is understandable.
I think it is possible.
HDRMaster small update, download from the link: https://ssoftadd.github.io/hdrMasterPage.html
Add the previous feature request. If the "Store Mode" is "Save to a special directory", then it is possible to set this special directory, where all preview and crop images will be saved. Also fix two bugs:
1. Now the rotation slider (in HDR Master property page) in degrease (from 0 to 360) instead of radians
2. Now the texture image node in the shader in non-color mode, because hdr-files images not require gamma correction.
