Geometry Shader for the hidden Options in mr 3.8
mr 3.8 Options Geoshader This experimental geometry shader enables the hidden mental ray 3.8 progressive rendering
option for Softimage.
Documentation and installation instructions are available in the si-community discussion. A sample scene is provided in this germanmentalray forum discussion
This (archive) shader by ctrl.studio for Max 2011 might or might not work using the sandboxing principle
of Softimage 2011 (mi file interpretation). For help with installing mi files in SI
2011, Hirazi Blue has kindly written an article on
-community. There are currently issues rendering strands with this shader.
Related plugins: ctrl_ghost_settings
local backup: mr3.8Options.zip
RoN43
Re: Geometry Shader for the hidden Options in mr 3.8
I have the same problem that Maximus. it work once and no effect with turn on\off!
jb_alvarado
Sorry @all, that I never writing here! I have no time for nothing
I rewriting the Code, and now you have a bit more Options (Subsampling Size, etc.).
By the IBL Mode I have a little problem... When I type the Mode, for example "approximate", it have no Effect and when I am delete the string, or re- render it works. Also with the mode light.
Pleas read the doku for the Options. An plugin/spdl comes, but I don't no when
Thanks a Lot Alvarado!!!
I haven't tried this yet, but ctrl.studio has made a Softimage-friendly (as in: including "spdl") version of their
ctrl_ghost_settings shader available on CGTalk: go to this post
As it's an attachment, you have to login to CGTalk first to be able to download it...
edit: I just sent ctrl.studio a private message, if they'd allow us to host it here locally... I'll get back to you...
Okay, I received the necessary permission to host this file locally.
Please note: this is the second version posted by ctrl.studio
FYI - This zip-file includes a file called "ctrl_ghost_settings.dll" and a file called "ctrl_ghost_settings.dll.x64". The first one is the 32 bits dll, which you won't need if you're using a 64 bits Softimage. In that case you'll have to rename the file "ctrl_ghost_settings.dll.x64" to "ctrl_ghost_settings.dll" for Softimage to be able to work with it...
Download it from here: ctrl_ghost_settings_2011bquoted from ctrl.studio @ CGTalk:
sry.. I packaged the wrong dlls.. there's some fg settings overwriting with prev addon. here a new one .. importons and ip are there so you may use them together with fg ..
pBarrelas
I definitely have to experiment this! Thanks!Hirazi Blue wrote:Okay, I received the necessary permission to host this file locally.
Please note: this is the second version posted by ctrl.studioDownload it from here: ctrl_ghost_settings_2011bquoted from ctrl.studio @ CGTalk:
I've installed ctrl.studio shaders. In your opinion which is better or lets say "with more implementations"? Ctrl.studio or jp_alvarado?
Well, it's hard to say...
The "ctrl.ghost..." obviously has more options, but if you're main interest is the progressive rendering you might as well use the one jb_alvarado wrote. In my opinion jb_alvarado gave up a little too soon. Given time he could've included more options. But that just my opinion (and I can understand the appearance of the "ctrl.ghost..." shader demotivated him somewhat)
Some of the "ctrl.ghost..." settings are superfluous as the options it tries to unhide are unhidden in Softimage to begin with.
The best part however about the "ctrl.ghost..." shader is the included SPDL, which creates a nice Softimage-style PPG for you... This doesn't sound like much, but is actually very nice...
pBarrelas
Thanks for the explanation!Hirazi Blue wrote:Well, it's hard to say...
Actually I was more interested on using FG with IR or Importons. I have to make some tests to see which are the advantages of this new feature!
pBarrelas
Does anyone had tried to use IBL?
If yes, what is the workflow? Do we still have to use the usual 2 methods of using HDRI/EXR images or is a different workflow?
Well I am no expert, so I shouldn't even attempt to answer this, but I did a little search around the web only to find there is very little information on the IBL workflow. Maybe it helps a little if you take a look at the settings of the sample-scene jb_alvarado provided earlier in this thread (find it here).
You'd probably have to use "his" geoshader to use this...
pBarrelas
Thanks Hirazi! I'll give it a look. Do you know what are the advantages over the "regular" methods?
No, sorry, I cannot help you there...
For all practical purposes the fact that this feature is not really extensively documented
and unsupported by Autodesk would generally make me
prefer the "regular" methods...
But again: I'm no expert... ;)
Maybe someone who knows more about this kind of "stuff" can take it from here?
pBarrelas
BenR
I'm interested too. I tried IBL with the geoshader. The results were fine but it actually took longer to render than doing IBL using FG with similar quality. I hope there is some technique I was missing or some advantage I'm unaware of.
Ben
Ben
as far as i have tested, IBL mode is better than ibl+fg, simply because you dont use FG wich is a big plus.
IBL + proressive rendering is awesome for preview purpose and see how the look will be, also the iBL produces real shadows on objects while the old one didnt.
To use it you just need 1 light in your scene, even if intensity is set at 0, otherwise you render black.
Plug an HDRI into environment, add a photographic exposure if you like and render.
The "enabled" mode is the full IBL method wich goes for best quality and calculation
The "Approximate" mode is for preview purpose, you lose quality but it render faster with better parameters.
Just play with samples and quality, dont expect to be like a bolt in time speed, i've found IBL excellent, i'm using it with progressive render and it rocks, in complex scenes it avoids the use of crap FG wich i hate.
pBarrelas
Hey Maximus, thanks for your input!
Would you like to post some images to illustrate what you just stated? I'm asking you this because I'm really having crappy results with it on some tests I've made!
