Sycles 2.4.1 V 2.4.1 released August 2026 —
download page: https://ssoftadd.github.io/syclesSecondGenPage.html / wiki with tutorials / all of Shekn's plugins / author on vimeo / si-community thread
yashugan
Hi, apologize my strange question, but i'm really not able to render the MYST in cycles. There is explanation of parameters? because i really was not able after hours to render it. Apologize me, probably i'm doing something wrong.... Thank you!
you mean a box with volume shader?yashugan wrote: 30 Apr 2020, 07:42 Hi, apologize my strange question, but i'm really not able to render the MYST in cycles. There is explanation of parameters? because i really was not able after hours to render it. Apologize me, probably i'm doing something wrong.... Thank you!
yashugan
is this way that the fog is drawed in cycles??? ..ops....
I think no. You can simulate the fog by adding cycScatterVolume node to the background light source. But in this case this background light will not emit any light to objects. Also Cycles supports only one background light, so there is no possibility to add one light with fog and one light with illumination.
But you can add the fog on the postprocessing, by rendering depth or mist pass.
yashugan
In the RENDER opstions there are 3 parameters under the group "MIST".
Start, Depth and Falloff. (very explicit on what they do) But they never work. I have to prepare something in the scene to see these parameters work? thank and apologize my non expert situation.
That Mist under render options, according to the Cycle documents, you should switch to that pass to see the effect. check follow pictures.(It different with depth)yashugan wrote: 01 May 2020, 13:52 In the RENDER opstions there are 3 parameters under the group "MIST".
Or for simple fog effects, I use a box with scatter volume shader, seems better control in this way.
MIST scatter volume shader
sirdavid32
Hi @Shekn ! I never had the opportunity to fully thank you for such incredible work you're doing with SYcles!
I've been a 5 year Blender user now, and I absolutely love how I can take my CYCLES knowledge and apply it here with SOFTIMAGE. A dream come true.
I got 2 questions:
1) Is there a way to work with the complete viewport "rendering" using a render region only? I have a TitanX card, I activated on preferences, and I sure notice the boost!
2) Is shader to AOVs implemented in your latest 1.9 release?
I got 2 questions:
Web: http://www.3dcinetv.com
yashugan
thank you Shekn, this will be very usefull!
sirdavid32
1. You can use quick preview render which cover the full viewport, but this mode is not the same as render preview in Blender. Each update of the scene will re-export all scene to the render engine, and with large scene it takes some time. Caching system helps a little, but not too much. Fast gpu can decrease the render time of one frame, but the time of the scene prepare stay the same. For render with low samples this prepare takes the most time of the whole render time.
2. Shader AOVs are implemented in the latest version 1.9.
Bennyhase
Question about the "SToon" for Cycles for Softimage: anybody used it ? On my side rendering with Stoon will not work. I´m following exactly the documentation. Cycle itself will work, but SToon don´t. Have set OSL-Shading, made all propertys, doing exactly same thing couple of times, but no luck.
Yes I notice this exactly as you described... sometimes even with shader parameter adjust, Sycle will re-export all scene. which makes the progressive update not that useful.Shekn wrote: 06 May 2020, 10:02 sirdavid32
You have to implement another layer, complete separated with Cycle API, if really want a true "cache all scene object in memory" ?
Bennyhase. You are right, SToon shaders does not work with the current version of the Sycles. This is very strange and I will try to understand, why it happens.
opoppopopp. May be sometimes I will rewrite connection between Softimage and Cycles render engine to make it more smart. SitoA is a good reference for it. But I don't know when I will find the time and, more important, the courage for this process.
Bennyhase
Hello Shekn, thanks for Reply. One Question: My system works only a few couple of renderings with Sycles inside Softimage XSI on my GPU´s. I can render about a dozen renderings (q-rendering or preview) with GPU and then only black renderings. After restarting Softimage i can render with GPU, after a while black renderings again. The same if i´m using one card or all 4 cards i have. No other application is open. I have the newest driver installed. Win10... 1x RTX 2080Ti with 12 GBRam, 2x 1080Ti, 1x 1070Ti. No fancy scene, only the dinosaur to render...
Hmm, also very strange. May be you can record small video with this behaviour. For better understanding, what's happens. And what you say occurs also on the CPU, or only when you use GPU? And what happens, when you use both CPU and GPU?
Bennyhase
For quick reply: rendering for CPU only all is fine (but this is indeed very low and not my goal). It happens in hybrid mode (CPU and GPU) and GPU only mode. I´m trying to make a small video in a few hours.
I bet it is because the API itself, not Sycle, hardware, driver version, opencl etc.Bennyhase wrote: 07 May 2020, 15:22 Hello Shekn, thanks for Reply. One Question: My system works only a few couple of renderings with Sycles inside Softimage XSI on my GPU´s. I can render about a dozen renderings (q-rendering or preview) with GPU and then only black renderings. After restarting Softimage i can render with GPU, after a while black renderings again. The same if i´m using one card or all 4 cards i have. No other application is open. I have the newest driver installed. Win10... 1x RTX 2080Ti with 12 GBRam, 2x 1080Ti, 1x 1070Ti. No fancy scene, only the dinosaur to render...
my case, ryzen cpu + 1660 super hybrid works
