ET_AnimStore
Re: ET_AnimStore
http://www.ethivierge.com/scripting/et_animstore-v1-1/
Hopefully fixes issues. Now you shouldn't need to edit the __init__.py file. Let me know.
Cheers,
Eric T.
Cheers,
Eric T.
zossowosso
Re: ET_AnimStore
he he
EricTRocks you are a king
a big thank you to all these efforts now it's working
I'm going to enjoy this beautiful tool
a big thank again
a big thank again
'ERROR : 2011 - Unable to write well in English [CLSID\{F123FC55-ABD9-4D7F-9CDD-7F9D61E71FFE}] : %SUMATRAPATH%\ English.dll not found'
Re: ET_AnimStore
No prob.
"It's good to be da king"
ivemaker
- Skype: ivemaker
Re: ET_AnimStore
hi Eric, do my method work??
Re: ET_AnimStore
Yes.
ivemaker
- Skype: ivemaker
Re: ET_AnimStore
very good. if you have some problems, aks me.
Arthur
Arthur
calmasacow
Re: ET_AnimStore
Eric,
Suggestion, when doing your setup. You should have a button that stores the selection list of controllers. For instance you select all of you controller and hit a button that stores that list of controllers. The when you hit store Pose it will automatically know what it is storing information for eliminating the need to manually select all of the controllers every time you store a pose.
Re: ET_AnimStore
I can see the usefulness for this. I'll consider it for the next update.
Thanks,
Eric T.
Thanks,
Eric T.
Re: ET_AnimStore
From the Mailing List by Eric Thivierge
If you're like me not getting the updated page (with a version 2.20 as clickable link), you might want to access it through a proxy server as it doesn't seem possible for some (i.e. me) to get to the updated website otherwise...
edit: Google Translate does the trick also, set the "from" language to anything but English and the "to" language to English...
(Quoted from here)I just posted my latest version of ET_AnimStore. Version 2.0 was
totally reworked and now supports storing animation and more:
- Database driven for stability
- Password protected to ensure no accidental deletions
- Now able to store animation
- New pose / animation organization
- Projects
- Model Group
- Sets
- Poses aren't locked to 1 character
- Clean util to remove defunct poses
- Deletion hierarchy; delete a project, and model group and sets delete with it.
Videos and Download
http://www.ethivierge.com/animstore/
Re: ET_AnimStore
Really sorry about you not being able to access the page I have no idea why. :\
Re: ET_AnimStore
I'm sure, you're not to blame. It's probably a hoster mishap. So no worries about that! ;)
I just had to add the info in case someone else encountered the same problem.
P.S. Looks like a promising update, BTW...
Memag
Re: ET_AnimStore
Thanks Hirazi, Eric!
Re: ET_AnimStore
Thanks! I've had this update in my back pocket for a while. Just got time recently after Species to let it out.
What country are you in? I can check with my host to see if there is anything they can do.
Re: ET_AnimStore
I am from the Netherlands (just like Rork who was the only other person reporting similar behavior over at the xsibase recently). So I am thinking, maybe your hosting service is blocking Dutch addresses wholesale.
Re: ET_AnimStore
That'd be a problem to me if they were. I'll have them look into it.
bottleofram
Re: ET_AnimStore
Hi Eric,
I'm getting this error when opening keyboard mapping manager:
# ERROR : 2268 - This function is missing:
# <function: ET_AnimStore_CreatePoseList_Execute>
# <path: C:\Users\[username]\Autodesk\[workgroup]\Addons\ET_AnimStore_v2.20\Application\Plugins\ET_AnimStore_GUI.py>
Thought you might wanna know.
