Starcraft Ghost
ibra
- Skype: hendeweh
Re: Starcraft Ghost
can you tell me what are the EXACT operations you are using so that i can help ?
Contac
Re: Starcraft Ghost
i use extrude along normal and want this without any setting window.
i came frome max and when i extrude a edge i can make it quickly wihout any window setting that opens.
when i work in xsi the window opens again when i use the extrude operation.
any way to fix this ?
greetings, contac
greetings, contac
ibra
- Skype: hendeweh
Re: Starcraft Ghost
As far as ive seen, most things open a dialog box when u apply them in xsi
Windows that open up dont usually bother me so im not sure i can help you but it would be cool to know how disable them...
Maybe someone else knows how?
Re: Starcraft Ghost
Try the quick inset plugin from origin. It will speed up your workflow a bunch.
Contac
Re: Starcraft Ghost
What is your workflow in xsi? Did you use any plugin on your workflow? greetings contac
ibra
- Skype: hendeweh
Re: Starcraft Ghost
i made this tutorial on youtube: http://www.youtube.com/watch?v=1DzSZoD1djo
Here are my key bindings:
Split Polygon: Alt+A
Symmetrize Polygons: Alt+S
Isolate Selected Ctrl+Alt+Q
X:Scale
C:Rotate
V:Translate
N:create polygon tool
E:Edge Mode
T:Point Mode
U:Face mode
Ctrl:Snap
Ctrl+D:Duplicate
Clone Single w/o Options: Ctrl+Alt+X
R:Split Edge Tool
A:Add Edge Tool
Ctrl+Alt+T:Adj vertex
Ctrl+Alt+U:Adj faces
Ctrl+Alt+E:Adj Edges
Ctrl+Alt+W: Select 4 sided Polys
Detatch: Alt+D
Subdivide Polygons: Shift+D
X:Scale
C:Rotate
V:Translate
E:Edge Mode
T:Point Mode
U:Face mode
Ctrl:Snap
Ctrl+D:Duplicate
R:Split Edge Tool
A:Add Edge Tool
Detatch: Alt+D
Contac
Re: Starcraft Ghost
hello Daniel Brassard thanks for your answer, i prefer to use the tools inside xsi without a plugin.
hey ibra, big thanks for your effort,time and support. i have watch your tutorial video and this is very helpful for me, also i found the other tutorials awesome.
i follow this topic any time, its amazing art out of zbrush. the last of us is have awesome artworks.
http://www.zbrushcentral.com/showthread ... p-Pg-12%29
ibra did you make only character stuff or also hardsurface stuffs like vehicles ?
i post my character stuff next time hope you see in my started thread soon ibra and daniel brassard
greetings, contac
greetings, contac
Re: Starcraft Ghost
I wouldn't generally reject plugins like that, as they are after all often important extensionsContac wrote:i prefer to use the tools inside xsi without a plugin
to (missing) functionality and therefore were made for a good reason!
Contac
Re: Starcraft Ghost
Hirazi Blue, yeah i try to test the plugin but in general i dont like plugins for modeling, i pay many money for the program and expected to have good tools for modeling. i like plugins as extension like fluid simulation exocortex slipstreamvx but for modeling i expected to have good tools inside xsi.
greetings, contac
greetings, contac
ibra
- Skype: hendeweh
Re: Starcraft Ghost
Hey Contac im glad i can help! That post about the last of us almost gave me a heart attack! So beautiful sculpts! There is also that barbarian on zbrush central. I wana go for something like that next time! No i dont de vehicles although maybe i should try
Hey Hirazi Blue i saw quick inset plugin and mesh paint plugin, those are one of the coolest plugins i ever saw!!!! Im definitely gonna give them a shot especially mesh paint coz i usually do those operations manually!!!! Piotrek Marczak's work is amazing!
