Any thoughts on a Linux compile?
Also, did you know you don't need separate xsiaddons for 32/64bit flavours? You can have both in one. Just rename the dlls as *.32.dll and *.64.dll -- same for *.so linux files supposedly.
Motion Trail on viewport -Finally!
taro
Re: Motion Trail on viewport -Finally!
never thought. If I put source files here, can you complile them and upload here?alanf wrote:Any thoughts on a Linux compile?
But anyway, after v1.3 or lator. I want to fix it a little.
!? I didn't know that. I'll try to make it one file next time. Thanks!alanf wrote:Also, did you know you don't need separate xsiaddons for 32/64bit flavours? You can have both in one. Just rename the dlls as *.32.dll and *.64.dll -- same for *.so linux files supposedly.
alanf
If you post the source I will attempt to compile it. I can't promise I'll succeed, but if I do I will post the Linux compile here.
taro
Hi, alanf.
I forgot to say this, I made a new thread, and I put the source there.
viewtopic.php?f=9&t=2774
But it has a bug, and I'm trying to fix it.
Moderator edit: closed the thread, use the thread mentioned above instead - HB
