aaOcean open sourced...
aaOcean Suite The Open Source aaOcean Suite is a collection of Softimage ICE nodes and mental ray
shaders that implement Jerry Tessendorf's paper on simulating ocean waves, which is
currently the most widely used method for open water ocean surface modeling in the
industry.
This particular implementation presents itself as a 3D deforming grid inside Softimage, which then becomes the source of vector displacement map sequences that are sent to Mental Ray for final rendering. One of the benefits of using this approach is that it opens up the possibility of making other 3D objects inside Softimage react with the ocean grid via ICE. Another benefit is the speed that it brings in setting up your ocean right inside Softimage on a low resolution ocean grid to set basic parameters like wave height and speed, rather than rendering a sequence of images in Mental Ray. Works nicely in conjunction with Werner Ziemerink's Wave Curl.
local backup: aaocean.zip
author site: http://www.amaanakram.com / download: /?page_id=131 / si-community thread / repository @bitbucket.com (archive)
amaan
Re: aaOcean open sourced...
Hi all,
I have added new Softimage 2014 downloads here
https://bitbucket.org/amaanakram/aaocean/downloads
Ardworks: you need to set an expression on the 'Current Frame' so that it increments with the timeline. Does that not work?
ardworx
Amaan, nope I did that, did not fix it.
Greets,
ardworx
Greets,
ardworx
amaan
Is this with the mental ray, or the arnold shader?
amaan
Ardworx, I can't reproduce the reported behaviour. I set an expression, draw a render region and then step through the frames manually. I did not test Batch rendering
As a workaround, put an expression on the Current Frame parameter to 'Fc', and then plot it to an animation curve.
farhaad_yousefi
- Yahoo Messenger: farhaad_yousefi@yahoo.com
Aye ..!! video tutorial ..diissar wrote:thanks a lot Amaan,a video tutorial would be great!
rpmaguire
- Skype: eyekeystudio
I'm missing something here...
Can someone explain to me step by step how to install this plugin?
When i download "softimage 2013 rev235 stable" from bitbucket ... the rar file contains :
workgroup>application>plugins> aaOceanDeformer.dll & aaOceanDataShaderDefs.dll
workgroup>application>bin>nt-x86-64> aaOceanDataShader.dll
How do I install these?
http://www.amaanakram.com/plugins/aa_tessendorf/aa_ocean_doc_installation.html
on this webpage it says install add-on....but all there is is .dll's ..no .xsiaddon
I would really like to see this in action..
Help would be greatly appreciated.
Thanks,
Ryan
Thanks,
Ryan
amaan
Hi Ryan
The doc page you linked is no longer linked from my main website, and is obsolete.
you need to install the plugins in your softimage workgroup -- hence the "workgroup>application>plugins>..."
If you haven't made a workgroup already, softimage makes one for you in your c:\users\<username>\Autodesk... folder
rpmaguire
Hello amaan,
THanks for the reply!
I have created a workgroup and drag and dropped the files into there.
I restarted softimage and in the plug-in manager it is saying that the "aaOceanDataShaderDefs.dll" is invalild
I have nothing coming up on my GET>PROPERTY menu..
Any thoughts on this?
Thanks,
Ryan
Thanks,
Ryan
El Burritoh
I'm not having any luck getting it to show up in the menu either, but I don't have any errors. Everything seems to be loading fine. I tried manually applying an aaOcean ICE node in an ICE Tree, and piping it into a Set Point Position node, but that just made the mesh disappear entirely...
amaan
that is legacy workflow, and you might have seen it in the documentation you linked to that is no longer linked from my main website. Please ignore any documentation that is not linked to from my main website.
It's been two years now since it was removed, but you might have found it via google.
Please see the sample scenes to see how to play with ocean shaders/deformer. They are quite simple to pick up.
sirdavid32
Hi everyone!
I´m trying to install the aaOceanDeformer.dll via workgroup by placing it under (workgroup)\Application\Plugins\
But softimage can´t find neither the shader nor it deforms the sample scene.
What else am I missing to install? I´m using softimage sp2 2014.
Please help.
Thanks.
Please help.
Thanks.
Web: http://www.3dcinetv.com
Did you reboot Soft? are you using the correct version?
sirdavid32
I finally got it working. Made the workgroup appropiately.
Now I´d like to know how to generate foam, and how to use it with arnold renderer.
Cheers.
Cheers.
Pitcher
- Skype: mortenbartholdy
Hey Amaan,
Do you have any plans to port aaOcean to Redshift by any chance? Rendering out vector displacement maps takes up a lot of diskspace
//Morten
//Morten
mattmos
That's the kind of thing that I'd be more than happy to help crowdfund, if Amaan was willingPitcher wrote:Hey Amaan,
//Morten
Pitcher
Me too!
